Full Version: Key Replacement Lx300
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS
slimmy
Anyone know how to sort out a new key for LX300?
I have one working (grey end) and one snapped. If I turn just the broken bit it will not start up as
the black bit with the buttons on is now seperate.
I can see blanks on eBAY but must be more complicated than just going to a keysmith... or could I put the
working inside from the snapped key inside the new key? it still unlock the door etc. but the key part is not attached!
help?!
legendswraith
QUOTE (slimmy @ Dec 1 2008, 09:28 PM) *
help?!
not really depending on which key you get. If you get one with the shell to put the original electronics in then it will work if you take it to a keycutter with a tibbe machine. If you get a transponder key then you'll have to follow the programming procedure. I cut my own spare not long ago and programmed it fine
