January 7, 2009, 11:06 pm
[quote name='yoshi' post='47461' date='Apr 30 2003, 03:14 PM']Good advice.
However, if you submit the VIN number to www.usaveauto.co.uk, they will tell you year and colour.
If the car has had it's VIN altered, it probably won't match the data back from usaveauto. This is in conjunction with an Interpol check on the vehicle when being imported.
Low security on Jap cars made them an easy target - there are only 3 chassis numbers stamped on an Aristo and the keys typically come without microchip. They also come without locking wheel nuts which just shows you the low crime rate of Japan.
Most of the theft is through Hong Kong/Chinese/Jap gangs (yakuza anyone?), a small minority who use 'agencies' to front their stolen Jap cars.
So how do they get away with it? Simple, they change the VIN typically to a future number, therefore Interpol check the car and it comes clean. Why? Because technically the VIN number hasn't been assigned to any car as yet.
Example - if the VIN is JZS-161-19123, the '1' can be easily modified to a '4'. New VIN is JZS-161-49123.
This new VIN '49123' will enevitably pass through Interpol, AA etc. checks. Meanwhile the Jap police/Interpol are looking for car number '19123'
Other method is to alter the VIN to a current car on the road in Japan, a 'cloned VIN', again, fairly undetectable but much less common method.
By checking the VIN with www.usaveauto.co.uk you can locate the date of manufacture, if it doesn't match the your car's supposed date of manufacture then it's a stoler.
Final and sure method is the chemical test on the bulkhead VIN, which can be carried out by police stolen car squad. This is sure fire and will tell you straight away if there is any filler or alteration.[/quote]
Had a look at an aristo last week, someone told me about this post, and the vin plate had been messed with, and log book was saying GS300,didn't buy in the end, but wished i had seen this post before as i could of checked the vin plate
