lex28
February 17, 2009, 11:57 pm
CAR: IS200 Sport 110k
i know its the quickest car!, but ive noticed power loss and i can just about beat grannies in fiesta's!
it has been serviced not that long ago, oil, filter etc but im not happy with the performance anymore
what could be the reason for the loss? really weak pushing upto 70-80 and on wards..tire pressure is fine.
1st gear i can just get to 10-15mph..
could the timming belt be out?? it was changed at 60k
any help would be gud
Paz
Saraj
February 18, 2009, 12:05 am
Not too sure to be honest not mechinical, the only problem i had was when the car was not doing anything with my foot down, literally nothing no revs, but that was due to lack of fuel in the tank,
aido
February 18, 2009, 12:09 am
At a guess maybe your clutch is on the way out - you should be able to get to the mid 50s in 2nd gear so test that out. If not could be the clutch slipping.
Probably worth you trying to reset your ECU - just open the fusebox in the engine bay near the battery and remove the EFI and ETCS fuses for a minute, then go and give it a thrashing and see if that is any different? Mine once bogged down and that sorted it.
lex28
February 18, 2009, 12:20 am
hard to explain, it just sounds ill and knackered...not as smooth as it should be..esp gear change..
i will give that a go Aido..
ta
FuntimePhil
any warning lights on? could it be in limp mode?
aido
February 18, 2009, 12:23 am
Has the gearbox oil ever been changed thinking about it?
lex28
February 18, 2009, 12:29 am
no warning light at all..
not sure about the gear box oil
but i do know that the clutch is slipping slightly and juddering..doesnt feel as responsive
aido
February 18, 2009, 12:36 am
Probably getting that checked out sooner rather than later mate, otherwise it could damage your flywheel!
Try the ECU reset anyway but if the clutch is on the way out it's definitely worth changing it out as that'll be the problem
aztecbandit1
February 18, 2009, 7:13 am
Do the revs climb matey when you put your foot down but the speed stays low?
N2KHL
February 18, 2009, 9:56 am
I had a lack of power once in a crappy old corsa..the more i drove it the slower it got!! Turned out that the CAT had got blocked hence why it limped slower and slower. Got a new CAT from the scrappys and well i wouldnt say happy days but it was running as it should have lol!!
lex28
February 18, 2009, 10:26 am
[quote name='aztecbandit1' post='638529' date='Feb 18 2009, 07:13 AM']Do the revs climb matey when you put your foot down but the speed stays low?
[/quote]
ref upto 4rpm and doesnt wanna push any further
Dan_Harris
February 18, 2009, 11:02 am
had a similar thing and my clutch went aswell as flywheel, worth getting clutch inspected straight away imo, could it possibly be your coils?
stuie
February 18, 2009, 11:22 am
[quote name='lex28' post='638574' date='Feb 18 2009, 10:26 AM'][quote name='aztecbandit1' post='638529' date='Feb 18 2009, 07:13 AM']Do the revs climb matey when you put your foot down but the speed stays low?
[/quote]
[/quote]
up to 4k?
no wonder its not the quickest of cars nothing really happens below 4k take her to 5 or so then see how well it pulls
rig-pig
February 21, 2009, 2:07 pm
get it checked out at another garage m8
04r1
February 21, 2009, 9:12 pm
[/quote]
[/quote]
....I reckon some kids have shoved a tennis ball up its tail pipe....
sounds like a breathing problem....if it doesn't rev freely at a standstill give the throttle body a clean and blow the breathers through. Got to be worth a go
jomo
February 22, 2009, 1:24 am
I'd stab a guess at the coil packs mrself, my 306 S16 had 4 one for each plug and if one of those went that made it run like a bag o crap!
Full Colour Version:
Power Loss?
click here.
