jason_l
November 29, 2009, 10:30 am
*** Update ****
Got up to JDModified yesterday and although it was a slow day a have a few other bits to update so here it is.
The last few weeks i have been working on a few bits that are now prepped and ready to be welded onto the buggy. These have been left with them and will be added in the next week or so.
The first thing was to get the harness bar made. This was a bit of guess work as i didn't have the buggy with me to check fitment. I roughly measured it and checking fitment yesterday it is pretty much spot on.
[img]http://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057630472_587840472_10055758_6076850_n.jpg[/img]
detail of the inserts before welding........
[img]http://photos-e.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057625472_587840472_10055757_4299807_n.jpg[/img]
I Also settled on a final design for the rear light clusters and i decided to put the reverse lamps in the cluster as well. So i just need to add the rear fog, this will be placed under the number plate in the middle of the car.
This is what they looked like just after they where lazer cut out without being cleaned up.
[img]http://photos-g.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057670472_587840472_10055763_3475865_n.jpg[/img]
I got them made from 5mm steel so that they will have a 2.5mm radius to keep mr IVA happy
They have all been rounded off and have bolts ready for the lights to be fitted in place.
[img]http://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057675472_587840472_10055764_7738042_n.jpg[/img]
[img]http://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057680472_587840472_10055765_5691188_n.jpg[/img]
[img]http://photos-b.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057685472_587840472_10055766_1034193_n.jpg[/img]
Also been working on the side vents for the rear. These came with raised strips over them which i really don't like so i decided to remove them. Im still working on these and i almost have one done but they take alot of sanding, checking, sanding again etc.
This is what they looked like when they arrived.......
[img]http://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057640472_587840472_10055759_4268718_n.jpg[/img]
[img]http://photos-e.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057650472_587840472_10055760_6329233_n.jpg[/img]
and this is what they look like after a good sanding and a bit of primer. Loads better i think.........
[img]http://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057655472_587840472_10055761_3679617_n.jpg[/img]
[img]http://photos-a.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057665472_587840472_10055762_6132549_n.jpg[/img]
The adjustable spoiler has also been welded in place now and doesn't look to bad to be honest. Yes the spoiler itself is MDF but it is just a jig that was used to get the correct spacing of the brackets. The finished spoiler will either be made from Carbon or green Acrylic. Not too sure yet........
[img]http://photos-h.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057690472_587840472_10055767_5514972_n.jpg[/img]
[img]http://photos-g.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057695472_587840472_10055768_3935041_n.jpg[/img]
While i was up there yesterday the only thing i really managed to get done was to grind a couple of mounts off the back that i no longer need and where in the way of where the harness bar will go. I really didn't feel 100% but had to get something done.
[img]http://photos-a.ak.fbcdn.net/hphotos-ak-snc3/hs011.snc3/11853_364057700472_587840472_10055769_2150140_n.jpg[/img]
And a few more pics i got.........
[img]http://photos-f.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057705472_587840472_10055770_5165263_n.jpg[/img]
[img]http://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs031.snc3/11853_364057715472_587840472_10055771_8297834_n.jpg[/img]
I will be up there on the 10/11/12th of December to finish off the seating and steering. We have decided to make up some steel box section seat rails for strength rather than just bolt them to the floor and the steering position is just all wrong. Plan is to cut the steering off and lower it and move it over to make it more comfortable and in the correct position.
I have taken the radiator away with me as next on my list of things to work on is the mounts for the rad and the fan attachments.
Thats it for now people, as always im happy to answer any questions/comments.
Jason
