Full Version: Altezza Diff Into Is200
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
kallabungo
I read on another forum somewhere that apparently the shafts coming out of the diff on the is200 have 4 bolt holes whereas the altezza has 6...?
Can anybody confirm this?
Im basically just wanting a straight swap over and am wondering if there is anything extra involved...?
Thanks.
Asi
i was going to start about this aswell so any help will be nice
thanks
Steviewevie
I don't know, but bear in mind that the Altezza is not just one model, e.g. there is the AS200 with the same engine as the IS200, and then there's the RS200 with the 3S-GE engine. And also manual versus automatic transmissions (don't know if that makes a difference to the diff).
kallabungo
Arent the RS200, AS200 and Altezza all badged with the actual model they are...?
Noel
[quote name='kallabungo' post='644000' date='Mar 9 2009, 05:31 PM']I read on another forum somewhere that apparently the shafts coming out of the diff on the is200 have 4 bolt holes whereas the altezza has 6...?
Thanks.[/quote]
Yes you are correct...
A few points to keep in mind ...
Manual RS200 up to 2002 (changed mid to late 2001 apparently) have a Torsion diff with a 4.1 final drive, 2002 have a 4.3 final drive...
Auto (5speed) only got a LSD as an optional extra!
Monster Mat is the expert on here regarding whats involved and has alot of posts up about the likes over the years ... be worth your while searching through the old threads...
HTH
Steviewevie
[quote name='kallabungo' post='644018' date='Mar 9 2009, 06:47 PM']Arent the RS200, AS200 and Altezza all badged with the actual model they are...?[/quote]
The RS200 and AS200 are the main two variants of the Altezza. There is also the AS300 (estate).
My point was that you may need to check a lot more detail just than whether it comes out of an Altezza, i.e. which model of Altezza with which transmission.
Asi
i was wondeirng the one on for sale in the sale section. would that fit is200
thanks
kallabungo
[quote name='asi' post='644065' date='Mar 9 2009, 08:44 PM']i was wondeirng the one on for sale in the sale section. would that fit is200
thanks[/quote]
Yeah it will, but as far as im aware you'll need the correct shafts to go with it...
Asi
awryt then might aswell me buying the is200 sport diff
thanks for help
Monster-Mat
the is200 and altezza drive shafts are different, 4 bolt for the is200, and 6 bolt for the altezza
Full Colour Version: Altezza Diff Into Is200
