hawk77
April 14, 2009, 12:32 pm
My fog lights suddenly stopped working....both of them. I've checked the bulbs, all the fuses....but nothing. Everything seems to be ok. But still no go.
Any ideas why they would not work anymore?
tomo1981
April 14, 2009, 12:50 pm
I bet the housing on the rear is all corroded, take tham out and have a look, Its a common problem and is caused by salt water splashing through the brake disc vents on the plastic splash guard.
norlec
April 14, 2009, 12:53 pm
The only other thing it can be is the switch I would suggest checking the voltage to the switch and if that is OK your question is answered.
best of luck with it
Norman
MacRS200
April 14, 2009, 1:06 pm
Front or rear fogs?
hawk77
April 14, 2009, 1:37 pm
[quote name='MacRS200' post='656351' date='Apr 14 2009, 01:06 PM']Front or rear fogs?[/quote]
Dam' I always forget something ....23:41 and my eyes are half shut. Front fog lights. Strange though...they both worked this morning and they both stopped working this afternoon....
Cheers.
MacRS200
April 14, 2009, 2:06 pm
[quote name='hawk77' post='656356' date='Apr 14 2009, 02:37 PM'][quote name='MacRS200' post='656351' date='Apr 14 2009, 01:06 PM']Front or rear fogs?[/quote]
Cheers.
[/quote]
Have you checked the fuse in the passenger footwell fuse box?
Also are the tail lights working?
Could also be the relay.
Wiring diagram [url="http://bahamutcars.free.fr/workshop/IS_98-05/ewd/ewd368e/h_system/system.html?code=ffl-rhd"]HERE[/url]
April 14, 2009, 3:10 pm
Cheers.
[/quote]
Is it really that Foggy in Oz?
or you being a little chavvy?
hawk77
April 15, 2009, 12:39 pm
[quote name='sparkystav' post='656389' date='Apr 14 2009, 03:10 PM'][quote name='hawk77' post='656356' date='Apr 14 2009, 02:37 PM'][quote name='MacRS200' post='656351' date='Apr 14 2009, 01:06 PM']Front or rear fogs?[/quote]
Cheers.
[/quote]
[/quote]
Nah mate, after a whole day of work I am really tired and sometimes I do realise that I am half asleep but I can still write emails...and sometimes(only sometimes) they do make sense ...in a way.
hawk77
April 15, 2009, 12:48 pm
[quote name='MacRS200' post='656365' date='Apr 14 2009, 02:06 PM'][quote name='hawk77' post='656356' date='Apr 14 2009, 02:37 PM'][quote name='MacRS200' post='656351' date='Apr 14 2009, 01:06 PM']Front or rear fogs?[/quote]
Cheers.
[/quote]
[/quote]
Do you know by any chance where is the relay located?
April 15, 2009, 5:52 pm
use this workshop manual mate:
[url="http://www.bahamutcars.com/workshop/IS_98-05/index.html"]http://www.bahamutcars.com/workshop/IS_98-05/index.html[/url]
hawk77
April 15, 2009, 9:36 pm
[quote name='sparkystav' post='656807' date='Apr 15 2009, 05:52 PM']use this workshop manual mate:
Stav[/quote]
Cheers mate. I've had a quick look but I couldn't find the relay for the fog lights. I found where the fuse for it but no relay. It might be connected with a different relay? Any help would be greatly appreciated.
Many thanks.
April 15, 2009, 10:18 pm
Didnt look far did you?
[url="http://www.bahamutcars.com/workshop/IS_98-05/rm/rm684e/m_be_0043.pdf"]http://www.bahamutcars.com/workshop/IS_98-...e/m_be_0043.pdf[/url]
hawk77
April 16, 2009, 9:31 pm
[quote name='sparkystav' post='656949' date='Apr 15 2009, 11:18 PM']Didnt look far did you?
[url="http://www.bahamutcars.com/workshop/IS_98-05/rm/rm684e/m_be_0043.pdf"]http://www.bahamutcars.com/workshop/IS_98-...e/m_be_0043.pdf[/url][/quote]
Thanks mate. I meant in the car. I've looked around the fuse boxes on both sides, but I couldn't find a relay for the fog lights. Just a bunch of wires and plugs and the fuse box. I will check the switch on Saturday as well.
Thank you for your help so far.
MacRS200
April 17, 2009, 7:35 am
[quote name='hawk77' post='657299' date='Apr 16 2009, 10:31 PM'][quote name='sparkystav' post='656949' date='Apr 15 2009, 11:18 PM']Didnt look far did you?
[/quote]
Relays are on the back of the fuse box, you need to unplug all the wires and take the fuse box out to get at them!
hawk77
April 17, 2009, 8:19 am
[quote name='MacRS200' post='657386' date='Apr 17 2009, 08:35 AM'][quote name='hawk77' post='657299' date='Apr 16 2009, 10:31 PM'][quote name='sparkystav' post='656949' date='Apr 15 2009, 11:18 PM']Didnt look far did you?
[/quote]
[/quote]
Is there any other way to check if the relay is broken? Also, do you know the part number fo the front fog lights relay, so I can buy one before I open everything in there? Cheers.
Steviewevie
April 17, 2009, 8:29 am
[quote name='hawk77' post='657396' date='Apr 17 2009, 09:19 AM']Is there any other way to check if the relay is broken? Also, do you know the part number fo the front fog lights relay, so I can buy one before I open everything in there? Cheers.[/quote]
Part number for the fog lamp relay is either 90987-02012 or 90987-02020, your Lexus/Toyota dealer should be able to help you figure out which is right for your car.
See parts diagram below for the exact location of the relay, it's at the back of the passenger side fuse box, labelled as (7) in the picture :
[img]http://www.toyodiy.com/parts/diag_1CqPl73.png[/img]
Steviewevie
April 17, 2009, 9:03 am
[quote name='hawk77' post='657396' date='Apr 17 2009, 09:19 AM']Is there any other way to check if the relay is broken?[/quote]
You can check it, but you'll have to get to it first. See the procedures [url="http://www.bahamutcars.com/workshop/IS_98-05/rm/rm684e/m_be_0045.pdf"]here[/url], and specifically step 8 for checking the relay.
hawk77
April 18, 2009, 2:55 am
[quote name='Steviewevie' post='657406' date='Apr 17 2009, 09:29 AM'][quote name='hawk77' post='657396' date='Apr 17 2009, 09:19 AM']Is there any other way to check if the relay is broken? Also, do you know the part number fo the front fog lights relay, so I can buy one before I open everything in there? Cheers.[/quote]
[/quote]
Thanks mate. I will get into it today. I will check wtih the guys from Lexus on Monday.
braindead
April 18, 2009, 6:11 pm
As a matter of interest - when did folks have fog bad enough that fog lamps were required?
I can't remember last time I needed mine.
Steviewevie
April 18, 2009, 6:55 pm
Personally I find that the fog lamps are totally useless in fog anyway. I genuinely don't understand the point of them.
April 19, 2009, 7:35 am
I hate the people that drive round in the day with them.
Getting rid of mine when i get the car back. Got a lovely set of meshed ones to use as cold air feeds thanks to our resident homemade equipment guru.
click here.
