Full Version: One For The Audio Guys/gals..
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
jomo
Ok having a quick brouse on ebay and found this
[url="http://cgi.ebay.co.uk/Lexus-IS200-RX300-Mini-Disc-Autochanger-Genuine_W0QQitemZ370161142696QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item370161142696&_trksid=p3286.c0.m14&_trkparms=66%3A3|65%3A1|39%3A1|240%3A1318"]LEXUS MINI DISK[/url]
and was wondering if this whould fit my stnd head unit?
many thanks, Martin.
Steviewevie
You actually use mini discs ?
Asi
[quote name='Steviewevie' post='658233' date='Apr 20 2009, 09:39 AM']You actually use mini discs ?[/quote]
im going to say the same
I assume it would,
does it come with the needed cable as well?
Parthiban
As long as you don't have satnav, then it should work fine :)
Dodgydave
It will depend on what year your car is or more specifically what head unit you have fitted. If its an early head unit with the CD slot at the bottom, no. 13902, then it probably won't work.
When my head unit came up with error 3 I bought an external 6 CD changer, a genuine Toyota one, off ebay. But I found that it wouldn't work with my head unit. It would appear that allthough the earlier head unit has the socket on the back to plug an external disc changer or mini disk in it has not been fully implemented. I think this is the same reason why people with this model head unit haven't been able to get the Grom Audio adaptor to work.
If you have the newer model head unit then this should work fine, even if you have the sat nav it should still work but you will need a 'Y' connector to allow you to connect both the sat nav and the new mini disc player.
I hope this helps.
Dave.
Parthiban
[quote name='Dodgydave' post='658304' date='Apr 20 2009, 12:40 PM']If you have the newer model head unit then this should work fine[/quote]
Actually that's a good point, as that would explain why I can use a grom adaptor in my car with satnav as well.........I was just going on what Lexus said when I bought the car but I assume that wasn't correct information.
jomo
[quote name='sparkystav' post='658256' date='Apr 20 2009, 10:33 AM']I assume it would,
Stav[/quote]
Ad says its new with fitting kit, so would think so..
[quote name='Parthiban' post='658264' date='Apr 20 2009, 10:47 AM']As long as you don't have satnav, then it should work fine :)[/quote]
No sat nav..
[quote name='Dodgydave' post='658304' date='Apr 20 2009, 12:40 PM']Hi,
I hope this helps.
Dave.[/quote]
Stnd head unit with cd slt at top, '99 on a y plate..
[quote name='Asi' post='658254' date='Apr 20 2009, 10:30 AM'][quote name='Steviewevie' post='658233' date='Apr 20 2009, 09:39 AM']You actually use mini discs ?[/quote]
[/quote]
Only really use them when i'm roller skateing along Blackpool prom, listening to "Cliff Richards-Wired for sound!"
Parthiban
[quote name='jomo' post='658371' date='Apr 20 2009, 02:09 PM']Stnd head unit with cd slt at top, '99 on a y plate..[/quote]
I assume you meant '01 on a Y plate?
jomo
[quote name='Parthiban' post='658376' date='Apr 20 2009, 02:19 PM'][quote name='jomo' post='658371' date='Apr 20 2009, 02:09 PM']Stnd head unit with cd slt at top, '99 on a y plate..[/quote]
[/quote]
DOH! yes mate, my bad!
Full Colour Version: One For The Audio Guys/gals..
