It seems that I'm not having alot of luck with this car.
On the way to work (10mins ago) changing down the gears coming up to a roundabout, into second, clutch up - it judders like an absolute kanagaroo. "Hey?" I thought ......nevermind, must have just m is-judged it. It then drove fine. HOWEVER......turned the radio down, and I could hear that everytime I use the clutch (up or down) it sounds like an air pump pumping - especially if it's partly engaging then dis-engaging (i.e. when reversing and you go on/off the cluthch) and it sounds REALLY bad then. Will this just go away, have I got air in the system, do I need to do anything?
Any advice appreciated !
Thanks all
Tony
