Full Version: Mk2 Gs300 Speedometer Not Working
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
garethr
The VSC and ABS lights have been on, and the code said right rear wheel sensor. Replaced it, no difference, so investigated further today.
Had the car up on the lift, removed the rear sensors, lots of swarf, peered into the holes, found the problem - something had worn down the ABS rings.
Removed a driveshaft nut and tapped the shaft back so that we could see the ring, and could see that something (dust seal?) had been rubbing against it. The other side is also worn own, so need two driveshafts. So far so good.
Put it back together. Drove home, and the speedo was behaving oddly, not reading below about 20, and now it's stopped working altogether, although the cruise control is working perfectly.
Any ideas? I thought the speedometer took its signal from the gearbox. How could we have affected it by messing about with the driveshaft/rear ABS sensors? Just coincidence?
katana92_uk
sorry cant help you with your problem
but i recognise your name from TIF and LSOC
ColinBarber
the speedo gets its signal from the ABS/VSC ECU which in turn gets its signals from all 4 ABS sensors.
Steviewevie
[quote name='ColinBarber' post='676810' date='Jun 19 2009, 08:09 AM']the speedo gets its signal from the ABS/VSC ECU which in turn gets its signals from all 4 ABS sensors.[/quote]
What is the gearbox speed sensor used for then ?
garethr
[quote name='ColinBarber' post='676810' date='Jun 19 2009, 08:09 AM']The speedo gets its signal from the ABS/VSC ECU which in turn gets its signals from all 4 ABS sensors.[/quote]
Thanks, that might explain it. Perhaps it could deal with one rear wheel sensor not working, but now we've disturbed the other rear sensor and two aren't working.
[quote name='Steviewevie' post='676816' date='Jun 19 2009, 08:21 AM']What is the gearbox speed sensor used for then?[/quote]The gearbox is working as normal, and, as I said, so is the cruise control, so those speed signals appear to be OK.
garethr
[quote name='katana92_uk' post='676775' date='Jun 18 2009, 10:53 PM']Sorry cant help you with your problem but I recognise your name from TIF and LSOC[/quote]
That's me. I still have the Soarer.
