xfoglia
June 19, 2009, 11:00 pm
hi all,
i am looking for a set of front brake calipers that can fit to my mk2 aristo....
pls pm me the details if any available
also, does the supra's one fit to aristo? which version of supra is it?
thanks
Anees
June 20, 2009, 7:03 am
Welcome to the club
You ideally need Supra MKIV Front brake callipers which are a straught swap i.e
This was them fitted to my Aristo:
[img]http://www.ranatech.co.uk/aristo/11.JPG[/img]
Steviewevie
June 20, 2009, 7:39 am
You can buy brake calipers for the GS/Aristo off eBay if you want to stick with the standard ones. The IS200 uses the same calipers.
garethr
June 20, 2009, 9:34 am
[quote name='Anees' post='677157' date='Jun 20 2009, 08:03 AM']You ideally need Supra MKIV Front brake callipers which are a straight swap....[/quote]
but you might need to change the wheels.
xfoglia
June 20, 2009, 10:48 am
THanks for kind replied
so does it mean that I need to change the wheel at the same time when using a mk4 supra calipers?
xfoglia
June 20, 2009, 10:53 am
[quote name='Steviewevie' post='677162' date='Jun 20 2009, 08:39 AM']You can buy brake calipers for the GS/Aristo off eBay if you want to stick with the standard ones. The IS200 uses the same calipers.[/quote]
the Lexus dealer told me is200/altezza doesn't use the same calipers as aristo. They even said aristo can't use the same one on GS300... Weird..
Steviewevie
June 20, 2009, 12:45 pm
[quote name='xfoglia' post='677210' date='Jun 20 2009, 11:48 AM']so does it mean that I need to change the wheel at the same time when using a mk4 supra calipers?[/quote]
It may just be that you need some spacers. You'd have to try it and see though.
[quote name='xfoglia' post='677214' date='Jun 20 2009, 11:53 AM'][quote name='Steviewevie' post='677162' date='Jun 20 2009, 08:39 AM']You can buy brake calipers for the GS/Aristo off eBay if you want to stick with the standard ones. The IS200 uses the same calipers.[/quote]
[/quote]
Yeah that's odd, I thought they were the same. Looking at the parts diagrams closely, it looks to me like the Aristo calipers are identical to the GS300 ones, although there's a very slight difference to the IS200 calipers. But the internals of the calipers (pistons, pads etc) look the same as the IS200.
garethr
June 20, 2009, 2:33 pm
I'm not sure about the IS200 calipers, although I believe that the front brackets are different from the GS 300 brackets, because the Supra calipers are a straight fit in the GS but need slightly offset inserts for the IS. GS/IS Pads are the same though.
The GS front calipers (Mk1 and Mk2) are shared with the Aristo (except the very early non-turbo), Soarer TT, "Japanese-spec" Mk4 Supra, SC430.
click here.
