Full Version: Gearbox Clunks When Shifting From Park To Drive
Lexus Owners Club > Lexus Models > Lexus Imports Clubs > Aristo Club
sopcom1
hi
the aristo v300 mk2 makes a noise or clunk when shifting from park to drive. what it could be?the transmission is still smooth, changes softly the gears.
norkep
Does it do this when starting from cold or all the time
Could be due to low oil level in the gearbox
When you change frpm "P" to "D", have your foot on the brake slightly (reduce the load on the gearbox) to see if it's down to the gearbox, you may even find you have a loose pin in the brake caliper that's making the noise, the car will jump forward so make sure no-one is in front
spikes
start the car in N then put into D....!! :winky:
