Full Version: Rs200 Key
Lexus Owners Club > Lexus Models > Lexus Imports Clubs > Altezza Club
papillonuk
New RS200 Z-EDITION owner... quick question about the keys... Well In my case 1 key... it a BLACK TWO button key... is this one of the master keys! also been doing a quick search threw the forum and neva knew tht most did not come with a factory immob. defo gonna try the remove blip trick 2moro and see...!
Robin H
welcome to the forum :D
papillonuk
Hiii... done the blip remove trick! car started.... no imob then... THANK GOD it Getting a cat1 this week.. lol... gonna go get a couple keys cut... the one that came with it is to say the least a bit iffy...! feels like it may snap... dont want tht do we.!.
Clond
Let me know how you get on - My local toyota dealer said the key couldn't be cut because there is no chassis number on imports !!!
Also the two pin key is not a master so get the central locking onto the cat 1 alarm system.
F_O_R_D_Y
i was under the impression there were chassis numbers on imports as you can insure your import on the chassis number until you have a registered plate number off the dvla. i would double check that if i was you
Monster-Mat
[quote name='Clond' post='685857' date='Aug 13 2009, 08:43 PM']Let me know how you get on - My local toyota dealer said the key couldn't be cut because there is no chassis number on imports !!!
Also the two pin key is not a master so get the central locking onto the cat 1 alarm system.[/quote]
your dealer is a Knob then and talking utter rubbish,
Clond
thanks Mon-M
Perhaps explaining why he's a nob and what the real facts are might be err .......... less Knobbish !
griderjn
the Netz dealer told me that there is a number on the door that corresponds with your key.
I only have the one key myself, and plan on getting one or two more.
they have to pull the panel off of the driver side door, and get a number, or code or something.
i will do my best to be on the spot when they do it, the mechanic knows me fairly well now,
and they do not seem to have a problem with me nosing around in the garage when i am there to pick up parts.
so, when i get my back-up key, i will chime in again.
RS200BEAMS
Does anyone know where to get the 2 button key FOB's for an Altezza. I have tried everywhere.
Paulus2
[quote name='RS200BEAMS' date='11 September 2009 - 03:02 PM' timestamp='1252634573' post='690056']
[/quote]
Ditto.
E910
[quote name='Monster-Mat' date='31 August 2009 - 05:27 AM' timestamp='1251649652' post='688303']
your dealer is a Knob then and talking utter rubbish,[/quote] x2
As they're not transponder keys any half decent locksmith should be able to cut you one. They can trace the original key. They don't need numbers if they have a sample.
[/quote] Try here -> http://z4.invisionfree.com/lexusaltezzaclub/index.php?showtopic=9792
night_51
I been lookin ages for the 2 button key as mine snapped so am havin to use the spare (none remote 1) :(
griderjn
http://www.toyodiy.com/parts/p_J_1999_TOYOTA_ALTEZZA_SXE10-AEFVF_8420.2.html?hl=89070A
order the part through your friendly neighborhood Toyota Dealer
ormi
1)two button key is the master
2)no hidden numbers anywhere that will give you a key number
3)you can walk in to any toyota dealer give them the chassis number and they can get a key cut from that(takes ten days)
4)2 button fob easy to come by walk in to toyota.
5)EVERY CAR ON THE ROAD has a chassis number or some form of frame number (vosa wont let you mot a car with no chassis number)
griderjn
[quote name='ormi' date='07 September 2010 - 07:17 PM' timestamp='1283883421' post='731628']
[/quote]
When i got my replacement keys the NETZ mechanic pulled the barrel out of the driver side door.
He either used a number from the barrel to program the key, or programed the barrel with a number from the key.
Full Colour Version: Rs200 Key
