Leexus
May 16, 2003, 1:13 pm
I just realized that my boot/trunk won't open when I pull the handle under the driver's seat
. It works fine with the key. What's wrong? Anyone can help?
Brettster
May 16, 2003, 1:33 pm
Have you disabled the handle by turning the key in the lock the other way?
if you do that you can only open it with the button on the remote
yemgi
May 16, 2003, 1:35 pm
the cable may have gone off the lock mechanism.
Remove your trunk's garnishment and verify tha cable always is in the orange wheel that activate the lock.
If so, try pulling it from the trunk, if it works, it should be the handle side that has a problem.
Monster-Mat
May 16, 2003, 2:31 pm
Allen, its the lever near the fuel flap release you wanna pull.
the one under the seat is to move the set back and forth
what...........
what, what av i said
Chris.S
May 16, 2003, 3:28 pm
[i]Its sounds to me as though you've deadlocked the boot
Turn the lock from == to [] if you can understand my little diagram of the lock barrel [/i]
Fever
May 16, 2003, 4:07 pm
Worth while following Bret and Chris' advise first.....before ripping your boot apart!!
Leexus
May 19, 2003, 11:16 am
Thanks for everyones advice!
Thank you too Mat
Will check it today!
Leexus
May 20, 2003, 2:49 pm
Brett and Chris were right. My brother locked my boot. Followed Brett and chris advice and voila
boot open!
