Full Version: Tyre Pressure
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
pejay786
Can anyone let me know what tyre pressures I should be running in psi :question:
I have 18" 6 spoke alloys with 225/40/18 tyres.
When I got the car it had 40 psi in all four tyres.
I have reduced them to 35 psi but a freind of mine said it should 33 psi :shutit: :crybaby:
Any advice please guys :question:
is300_dino
i think the majority are running between 33 upto about 36psi as you have said, so i came to the conclusion of running in the middle of that figure and i normally fill them up to either 34 or 35 depending what mood im in.
kam05
35psi- works well with the WIM setup.
Mind you I have the standard 17 inch alloys with 215/45/17 tyres and not 18" 6 spoke alloys with 225/40/18 tyres.
pejay786
[quote name='kam05' post='686716' date='Aug 20 2009, 12:05 PM']35psi- works well with the WIM setup.
Mind you I have the standard 17 inch alloys with 215/45/17 tyres and not 18" 6 spoke alloys with 225/40/18 tyres.[/quote]
Pardon my ignorance but whats a 'WIM' setup mate :question:
pejay786
[quote name='is300_dino' post='686711' date='Aug 20 2009, 11:44 AM']i think the majority are running between 33 upto about 36psi as you have said, so i came to the conclusion of running in the middle of that figure and i normally fill them up to either 34 or 35 depending what mood im in.[/quote]
Thanks mate
kam05
[quote name='pejay786' post='686720' date='Aug 20 2009, 12:24 PM']Pardon my ignorance but whats a 'WIM' setup mate :question:[/quote]
WIM- Wheels-in-motion, a geomerty specialist who has re-written the geometry settings on the IS200/300 to stop the front inside tyres from wearing out very quickly.
[url="http://www.wheels-inmotion.co.uk/tyres-wheels-lexus.php"]WIM website[/url]
The early IS200's suffered from front inside tyre wear.
pejay786
[quote name='kam05' post='686723' date='Aug 20 2009, 12:31 PM'][quote name='pejay786' post='686720' date='Aug 20 2009, 12:24 PM']Pardon my ignorance but whats a 'WIM' setup mate :question:[/quote]
[/quote]
Hmmmmmnnnnnn................... intresting, have you had it done and if so how much?
My car is a 2003 model so do you think mine will need doing?
kam05
Costs about £100 for the WIM setup.
Worth doing even if your front tyres don't wear out very fast on the inside edges, as a geometry setup also improves the handling of your car.
LOcKY
Wheres the nearest WIM setup for the Northeast of England? or to be more precise Hartlepool... land of the monkey hangers and fake death canoiest
Parthiban
According to Tony @ WIM, should be using 35psi all round :)
And yes best off getting your geo checked by a reputable centre, and using the settings created by Tony as the original Lexus settings are incorrect and cause severe inner tyre wear. If you haven't had it so far you've been pretty lucky!
pejay786
[quote name='Parthiban' post='687017' date='Aug 22 2009, 04:59 PM']According to Tony @ WIM, should be using 35psi all round :)
And yes best off getting your geo checked by a reputable centre, and using the settings created by Tony as the original Lexus settings are incorrect and cause severe inner tyre wear. If you haven't had it so far you've been pretty lucky![/quote]
Thanks for all the advice guys, 35 psi all round it is.
Does anyone know where to get a WIM setup in Manchester?
Full Colour Version: Tyre Pressure
