hi all
kevin here new to this forgive me for jumping in at the deep end but i am tearing out what little hair i have left because of a gs 430
a little history for you
been on lpg since almost new
ran well since 2002 till last year
would start every time fine when cold but would stall as soon as you put in gear (auto box) then would be extremely slow to restart sometimes not atall till battery flat
had been using a little water for a long time maybe only a pint a month or so would usually freeze the gas conversion when water was low
had checked on pc before work started diagnosed a misfire
so back to garage done cold compression test and results were poor 60 to 90 psi on all cyl one was down at 35 that was my missfire i guess so now to the water leak wasnt external so looked like head gasked had some small bubbles in rad pulled off both heads all valves on exhaust side were toasted on both heads got all ex valves replaced, heads pressure tested, skimmed new head set of gaskets pistons and cyl all looked fine as you would expect for a 90000 mile motor happy days the heads were ready for back on replaced t-belt aswell lots spent by now as you might have guessed
Now for the bad bit
turned the key and guess what still had missfire and next to know throttle response max 2000rpm
checked compression again all ok 140 to 150 psi checked spark all ok throttle flap not moving in response to pedal movement
back to computer cleared all faults except one throttle posistion sensor wouldnt clear ut i dont think that will cause a miss?????????????
just to put the tin hat on it im not right convinced the head gasket problem is sorted either still runs hotish rad hoses are faily hard but no bubbles in rad
has any one got a reason why i still have a miss and why my throttle sensor might have died
help plese this car is driving me stray
