swilliams
October 6, 2009, 8:04 pm
Hello,
I have a GS300. I am unable to use the key fobs. The previous owner said they worked up until he set the alarm off one day and had to disconnect the battery. Is there some sort of sequence that will reset the fobs for use again? My last resort will be to go to the Lexus dealer. Please email me at stacy4nyc@yahoo.com
Thank you!!
-S
fildigger
October 6, 2009, 11:31 pm
MMMMMMmmmmm....!!!!
This UK site Lacks activity !
swilliams, Do a search on this site (plenty of info' on the Re-Code proceedure)
..I will be doing my New (ebay Key) on my Mk2 GS300 when it arrives this week!
Good luck. Phil.
TommyH
October 7, 2009, 6:43 am
Search is your friend my friend try [url="http://www.lexusownersclub.co.uk/forum/index.php?showtopic=48876"]THIS[/url]
Shuja Khan
October 17, 2009, 10:24 pm
[quote name='swilliams' post='693362' date='Oct 6 2009, 09:04 PM']Hello,
Thank you!!
-S[/quote]
If it is GS300-MK1, If I remember correctly, some one in past had posted a post could not find it now, said the following procedure, I did it for my MK1 (it was for MK1 only)
01. lock your car.
02. unlocak your car driver door.
03. sit inside, close door & lock the door
04. switch on your car, but do not start
05. hold your key fob lock & unlock keys together for 15 seconds near centre console
06. light will start flashing on key fob
07. 1st press unlock, then lock, light will stop flashing.
08. switch off your car, remove key, unlock door get out, close the door
09. now use your key fob to lock the door.
10. it should be able to lock all four doors.
If a key fob is already not paired with car, it will not work, to pair it, you may need to go to dealer who can do it for you.
plz post update.
thanks
Tony9r
October 21, 2009, 11:18 am
If it's a Mk1, try [url="http://www.lexusownersclub.co.uk/forum/index.php?showtopic=19509&st=0&p=413139&#entry413139"]THIS[/url]
