Full Version: Battery Specifications
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
GazJenno
Hi guys,
Im doing a project for uni about batterys and need to know the manufactures recommended specs on a GS300 Sport 1999 battery... Info needed includes the CCA/ CC (which is the cold cranking amps), Ah (amp hours) and the overall dimensions. Any copies of official lexus documents which have this info on would be awsome, I was hoping I could find this information in my owners manual and was going to scan it but I cant seem to find it.
Cheers Guys
Gaz
P.S. Need this by friday :(
GazJenno
Anyone got any info or know where it would be? Its not in the owners manual.
fildigger
Have a Trip down to Halfords..................They will stock the Correct Replacement Battery ( I believe there Product is Made by Yuasa) All the Spec' will be on there charts & on the Battery itself!
..Once you have found the correct Type Code, you may be able to use the Net to get a more in depth Spec' on the Actual Battery Recommended.
GazJenno
[quote name='fildigger' post='695080' date='Oct 21 2009, 03:16 PM']Have a Trip down to Halfords..................They will stock the Correct Replacement Battery ( I believe there Product is Made by Yuasa) All the Spec' will be on there charts & on the Battery itself!
..Once you have found the correct Type Code, you may be able to use the Net to get a more in depth Spec' on the Actual Battery Recommended.[/quote]
Thanks for your reply... the detials had to be from Lexus themselves which I obtained by e-mailing lexus and suprisingly they gave me the exact information of the originally equipped battery which was nice of them. Thanks Again
Gaz
p.s. please see my new thread as I have another problem!
Full Colour Version: Battery Specifications
