Full Version: Just Bought An Is200 And Erm.....
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
Mbay
HI all, I'm new to LOC and have just bought myself an X reg 2001 IS200 in silver. Has a spoiler and body kit so assume it is a styling kit model.
The car drives like nothing I've driven before. Its FAB!!
Anyway, theres a few problems with it that I want to bottom out! The problems don't affect how it drives or at least I don't think it does!
I took it to my local Lexus dealer and they did a Vehicle Safety report.
For some reason the bonnet doesn't sit flush with the headlights and the grill, especially on the drivers side. The bonnet stay clip is broke so don't know if it might be that. I'll get some photos up when I can. Lexus said it looks like it may have had a new wing in the past as it looks newer. Lexus went onto say its a bodyshop issue and reccommended one to me.
The drivers side foglight is gone. Has condensation in it. Lexus wanted £275 to replace it! LOL!!
Something they said was important was there is an "oil leak on diff seals & rear cover" which is what it says on the report. No idea what that means.
Also the rear brake pads are 90% worn which is self explanatory. £130 to replace they wanted.
£20 for the bonnet stay clip.
Obviously the brakes are very important but I've no idea about the diff seals thingy. I can sort the brakes out but what do I do with the diff seals and the problem with the bonnet?
Any ideas on what the bonnet thing could be?
thanks.
MorrIS200
sounds like it could of been in a crash?
Mbay
[quote name='MorrIS200' post='700781' date='Dec 8 2009, 04:42 PM']sounds like it could of been in a crash?[/quote]
Well when the Lexus mechanic pointed it out to me I thought the same. Doesn't bother me though, its such a good motor!
MorrIS200
i fit doesnt bother you then i wouldnt worry. as long as its safe and runs good you have got a good car
where you from on merseyside by the way?
Mbay
[quote name='MorrIS200' post='700788' date='Dec 8 2009, 05:34 PM']i fit doesnt bother you then i wouldnt worry. as long as its safe and runs good you have got a good car
where you from on merseyside by the way?[/quote]
Im from south liverpool. Were bouts you from?
kam05
Welcome- enjoy the IS200, I've had my 2000/X reg IS200 for nearly 7 years now (bought it at 2.5 years old)- fantasic cars. This is the longest time I have owned any car, if I sold this IS200 I'd probably replace it with another IS200 or maybe a IS300.
Oh, the bonnet clip for the bonnet rod often break on the IS200- there are 2 sellers on ebay who are selling OEM replacement ones for £10-12.
Asi
yep bonnet clips break pretty easily. i bought mines from ebay for 12 quid. fog lights i have some. going to put up for sale soon. pm me if your interested mate.
MorrIS200
come to think about it i need one of these bonnet rod catches.
North Liverpool mate Crosby
Mbay
so any ideas on the diff thing?
took it to an autobody shop and they told me to lower the bonnet catch thing. will try it tomorrow and see what happens.
edeath
I would get the diff oil leak sorted pretty quickly. Look under the car at the rear and you'll see the diff in the centre. You should be able to see the rear of the diff and how bad the oil leak is. I expect most garages will be able to fix it.
Mbay
Just uploaded pictures of my is200, in my gallery, think you might be able to see the bonnet not sitting low enough. any idea how to make it lower or how to lower the catch?
what model is it coz i aint gots a clue?
Mbay
where should i go for the diff thing?
and how do i upload pics to a post?
Mbay
rite,
sorted sum pics out of my car and the problem with the bonnet.
I tried to lower the catch but it wont go any lower :tsktsk:
any ideas?
CLOSE UP OF THE BONNET NOT SITTING FLUSH
[img]http://img63.imageshack.us/img63/9005/dsc02221w.jpg[/img]
SHOT OF THE FRONT END, SEE WHAT I MEAN ABOUT THE BONNET! AND THE DRIVER SIDE FOG LIGHT
[img]http://img63.imageshack.us/img63/8476/dsc02224n.jpg[/img]
SHOT OF THE REAR END. I LOVE THE SPOILER!
[img]http://img710.imageshack.us/img710/3686/dsc02225.jpg[/img]
CLOSE UP OF THE BOOT LOCK WHICH IS CRACKED. How much to replace?
[img]http://img710.imageshack.us/img710/9623/dsc02226h.jpg[/img]
nedsram13a
Your drivers side is slightly raised, but your passenger one is nothing to worry about, they all have a slight gap above the headlamp (its where some people put there LED strips)
Regarding the crack on the boot, that part pulls off (3 screws inside the boot under the carpet), you need to remove it to change the number plate lights - i cant imagine there expensive to replace, maybe try e-bay or a scrap yard
kenfoxy
My bonnet clip broke at 6 years old. Got a replacement from Lexus Liverpool. They had it IN STOCK so I guess it is a common fault. Didn't cost much and easy to fit. My advice is if yours hasn't been replaced be very careful with it by easing the stay out and visa versa.
Yeldarb
The lock surround is about £40+vat and they come painted already, very easy to swap over if you have a 10mm socket and extension. I broke mine early on this year fitting the rear view camera!!
Mbay
[quote name='nedsram13a' post='701825' date='Dec 17 2009, 07:40 AM']Your drivers side is slightly raised, but your passenger one is nothing to worry about, they all have a slight gap above the headlamp (its where some people put there LED strips)
Regarding the crack on the boot, that part pulls off (3 screws inside the boot under the carpet), you need to remove it to change the number plate lights - i cant imagine there expensive to replace, maybe try e-bay or a scrap yard[/quote]
so how can i sort out the gap? is it the bonnet catch, should i go to a body shop?
nedsram13a
Im unsure. Have you tried the bump stops (the plastic screw down things near the headlights?
Mbay
[quote name='nedsram13a' post='701938' date='Dec 17 2009, 08:05 PM']Im unsure. Have you tried the bump stops (the plastic screw down things near the headlights?[/quote]
tried them. theyre screwed all the way and tried without. still no joy!
also, to save me opening a new thread, if i want hids for my main, dipped and fogs, would i need 3 separate kits (meaning 3 pairs of ballasts?)
