QUOTE(chris vince @ Sep 2 2006, 04:09 PM) [snapback]379316[/snapback]
Hi Dundee,
I don't know if you have sorted your dash lights out yet?
If not, I repaired a LS with the same problem this week, see the posting under LCD repairs.
Chris
Hi Chris,
I am very interested in this topic, can you point me to or cut and paste the LCD Repirs topic
as I could not find it, also on our LS400 the LCD on time and radio station is getting darker from the
bottom, as if the liquid cristal is flowing out, is there a repair for this? Or is it a new unit, this is the one above radio by the way not speedo, the speedo lights and fuel gauge etc. flickers on at ignition,
then goes off when starting the engine, after driving for about 10minutes it flickers back to life.
It does not seem so bad when the weather is dry in the summer, when it rains it is worse, and
the timing of when it comes back on varies, in daylight it is not so much of a problem but at
night it is not good.
Is this a ECU failure? Can it be repaired or needs replacement?
Any knowledge of this would be appreciated.
Regards,
Greywolf
