Full Version: It Related: Messenger Popups
Lexus Owners Club > General Lexus Forums > Lexus Owners Club Lounge
Steve
Ok boffins.. this is past me as I hate MS to be honest
My friend keeps getting messenger popups and even his kids have these pop ups advertising pr0n
Could someone direct me on how to disable messenger?
cheerz
Matthew_McNally
start
settings
control panel
admin tools
services
Right click messenger service\
select properties
change startup type to Disabled
JonC
goto the control panel then add/remove programs
in there will be a section windows components remove windows messenger and msn messenger (if installed also)
this will get rid of messenger
also to stop anyone reinstalling and using messenger set the firewall to block the program and its ports and password protect the firewall
Steve
even though mine has it enabled i have never had one
but what was weird is that i set my mate up on the net using freeserve.. all hopy and working.. his kid has a go and the pop up appears 15 mins of being online.
first time i had ever seen one ... well apart from over a network in my old office.
reckon its untracable and it will be the next big thing.
Matthew_McNally
[quote name='Administrator' date='May 29 2003, 11:56 AM']even though mine has it enabled i have never had one[/quote]
could be because you are behind a firewall (either that - or your IP address isn't the 217.35.12.nnn one I just tried)
:whistling:
Chris.S
[i]I keep getting them aswell through AOL do I go through the same procedure ?[/i]
Steve
hats off to BT then
though i am using XP.. so this might be the reason.. my friend is using 2000
Matthew_McNally
[quote name='Administrator' date='May 29 2003, 12:23 PM']though i am using XP[/quote]
XP has a built in firewall- that is turned on by default. (lose2k dosn't)
so - unless you have turned it off yourself - you are behind a firewall
Matthew_McNally
[quote name='Chris Shipley' date='May 29 2003, 12:19 PM'][i]I keep getting them aswell through AOL do I go through the same procedure ?[/i][/quote]
yeah
do the same thing Chris - just disable the service
GRiM
Zonealarm :whistling:
Free to download [url="http://download.com.com/3000-2092-10039884.html?part=zonealarm&subj=dlpage&tag=button"]HERE[/url]
JonC
you could try the Hosts trick
its all pretty simple just a file to copy and paste and it blocks nasty pop ups and ads
available at www.k-lite.tk
MsW
I use pop-up stopper free download from
www.panicware.com
Works a treat
Steve
to stop net popups i use Mozilla browser.... pheonix
PI100
run an antivirus as from my past experience i had a virus which kept popping up windows of pron.
also try running adaware software (freeware i think) it will remove any spyware are nasty programs causing havoc.
as other members have suggested use pop up killer software.
(information came form my son)
Paul
Full Colour Version: It Related: Messenger Popups
