Full Version: Dampness In Headlights
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
IZZZY
Guys,
I know this has been mentioned previously but i didnt ever follow the thread.
i have dampness in my main headlights... its been there for a good few weeks now.. any thoughts on how to get this removed? cured?
ideally would like to fix this so i dont get it again.
thanks for your help guys,
Izzy
mattc
Might be a small crack in the headlight or the seal has gone allowing moisture in.
Only real fix is dismantle the headlight and reseal the lens etc or new headlight
Asi
could be that^^^^ time for a new healight.
Sheeldzy
Put a silica gel sachet in the back of it
IZZZY
anyone have any idea on a cost of a new headlight?
Maffison
Headlights are around £130 if i remember correct. I had the same problem with both of mine (common fault on older IS) so decided to fix it while fitting angel eyes. One headlight stayed clear but the other fogged up again. So took it back out and opened it back up, resealed with more silicone, reassembled and refitted. Moisture is back yet again! So think i will be getting a new pair of units too. If its not bad on yours you can try removing the two sponges in each unit and drying them. There are two flaps on the rear of the units which are probably difficult to open whilst on the car (one top and one bottom). Might be a decent temporary fix till warmer weather comes.
Billnick
Can anyone recommend a sealant to use when I put my headlights back together?
Do we need to use a thermally activated one incase I ever need to take them apart again or will any silicone sealer suffice?
Ideally want one that is close the OEM seal - what has everyone used?
Rez89
i am in the same situation as Izzy as of last week! so i think this gives me an exuse to get the Dark headlights B)
billyo
[quote name='Rez89' post='710552' date='Feb 23 2010, 03:58 PM']i am in the same situation as Izzy as of last week! so i think this gives me an exuse to get the Dark headlights B)[/quote]
Jap parts do original headlamp.i ordered from their. one had plastic lug broken they replaced straight away no problems
Full Colour Version: Dampness In Headlights
