Full Version: Electric Seats
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 Club
franmac
Is it possible to replace mnually adjustable seats with electrically adjustable ones ?
Is there a block connector somewhere near the seat to plug in,
or do you need to run a separate power supply to the seat ?
Eamonn.
franmac
Anybody got any help with this ..... going to purchase the seats tomorrow and really need some advice.
My car has manually adjustable cloth seats .... I'm going to replace them with electrically adjustable
half leather seats. Need to know if supplying the seats with power is going to be a problem.
I don't mind if I have to run a separate power supply to the seats, but it would be very handy if there
was a pre-existing block to just plug into.
Eamonn.
Parthiban
i dont really have a clue about this, but if it is one of the cars with both front electric seats, (post 2001), then i would assume that there would be some sort of electric connection where the seats are.
however, if it was one of the earlier models, with only an electric drivers seat, then it may not have any electrics under the passenger seat.
sorry i cant give you any more help :withstupid:
altezzaz
Can't say for sure, I haven't pulled the carpets up yet, but I do know that my car has the wiring looms for the heated seats so I don't see why not....
DUNCAN
If you don't have a plug under the carpet, in the seating area, All you need to run is a single power supply rated at 30 amps, and an earth. The switches an everything else is built into the seat
The plug if you can find one, should hold two wires...A white which carries the power supply, and awhite/black which is the earth...
Good Luck Eamonn.
Bobski
[quote name='Parthiban' date='Jun 2 2003, 08:22 AM']i dont really have a clue about this, but if it is one of the cars with both front electric seats, (post 2001), then i would assume that there would be some sort of electric connection where the seats are.[/quote]
Some cars from 2000 have both too.
Not that this helps in any way :blink:
franmac
Many thanks to all ...... have my seats in and working.
Had to run a live to the seat ...... earth already there.
Very pleased.
Thanks again,
Eamonn.
Full Colour Version: Electric Seats
