Full Version: Mot Coming Up Gs300 Sport
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
samurai69
My MOT is due up in 2 weeks time, are there any things i need to look out for before putting it in
Its a 96 gs300 sport with just over 100k on the clock, regular dealer services up to feb last year
i know tghe cat has split and will need replacing and i have recently fitted two new rear boxes and front pads and i have reaer pads if necessary...............but is there anything else which is common to go wrong for the MOT at this age or mileage
thanks
TigerFish
There isn't anything I can think of other than the standard double check for any car. Bulbs, wiper blades etc. Mine just passed with 217k miles, so your mileage shouldn't cause you any problems.
kevinsgs300
check front top and bottom bal joints for any wear. i had advisories on these getting bad.
TigerFish
[quote name='kevinsgs300' post='708848' date='Feb 12 2010, 01:46 PM']check front top and bottom bal joints for any wear. i had advisories on these getting bad.[/quote]
I did get both bottom balljoints including delivery for £50 on ebay, the seller still has some. Top wihsbones (with the balljoints built in) are not so cheap, although I believe blueprint do make those. Luckily I had a spare wishbone for each side already, and used one when I needed to do the the nearside (see link in sig for tutorial).
TigerFish
Edit: Duplicate of above
samurai69
[quote name='TigerFish' post='708975' date='Feb 13 2010, 04:55 PM']Edit: Duplicate of above[/quote]
great, i will have a check of the ball joints and wishbones
luckily all bulbs have been replaced due to both rear lights blowing at the same time whilst driving half way over from portugal...............had to drive with just rear fogs for 40 or 50 miles..........ended up taping paper over them to diffuse them a bit as boot was so full couldnt get in to replace them.............and repleced both front sides after one of them blew a few months ago
and just before winter i got new wiper blades
just ordered the cat................hope its easy enough to fit
samurai69
sailed through...................just headlights need a slight adjustment up
Full Colour Version: Mot Coming Up Gs300 Sport
