[quote name='Andrew' date='Jun 4 2003, 06:09 PM']I've just taken delivery of a IS200 SE Auto Sat Nav. I had a phone fitted, but have been informed that you can't mute the audio because of the Sat Nav.
I've seen some posts that say you can get it to mute but you need to use a relay, however it doesn't say if this will work in a car with Sat Nav.
Does anyone know if you can mute the audio in a car with Sat Nav, using a relay or not?
Andrew[/quote]
Hi Andy,
You need to remove the radio(you'll find out how to do this by looking on the workshop forums).
There is a GREY wire on the back of the radio, this is the accessory supply wire to the radio from the ignition.
Cut this wire behind the radio, and extend both cut ends to a 5 pin relay.
The end connected to the radio goes to pin 30 on the relay, and the other end of the grey wire goes to pin 87a and 85.
The yellow mute wire from your phone kit goes to pin 86.
Pin 87 isn't used, but make sure it's covered over with a spare terminal.
JOB DONE.....
Replace radio, being very careful not to scatch the dash....
Hope this helps buddy!!!!
