Full Version: Gs 300 2007: Check Vsc And Warning Lights
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club > Engine & Transmission
mojo7676
Hi
fairly new to the forum and Lexus. It's my first lexus, actually: 2007 gs 300 se-l. Anyway, love the car but had this problem twice, now: check vsc as well as a series of lights: engine management, traction control and brakes. the first time, i took it to a mech who stuck his machine on the car, deleted the faults (but found nothing stored). two weeks later, the same thing again. Any suggestions/ideas hugely appreciated. Done a google search and found little of use.
thanks.
mojo
dave1
Sorry to hear of your problem and hopefully it is nothing too serious.
How long have you had the car?
Did you buy private or dealer?
When in 2007 was it registered?
The Editor
Known problem....
You will need:
1 A new ECU
2 2x Oxygen Sensors
3 An oil and filter change
Total cost (if not under warranty - circa £3,000)!!!! - Yes you did read that right!
If you bought the car from a Lexus dealer it should be covered under warranty - if not, you are in for a very expensive bill I'm afraid. Lexus know about this problem (in fact they have even extended the cover to 5 years for this item) but they refuse to do a recall for it.
knitware
This happened to my car, Check VSC etc. The above poster is spot on. I had to change ECU, 2 x O2 sensors and an oil and filter. The cost was around £3k. This was settled between Lexus GB and the supplying dealer, thank god!
dave1
[quote name='The Editor' date='10 May 2010 - 10:52 AM' timestamp='1273485152' post='719704']
Known problem....
You will need:
1 A new ECU
2 2x Oxygen Sensors
[/quote]
If Lexus have extended the cover for this problem to 5 years then surely a 2007 car with this fault should be covered. If it is late 2007 then it should be covered anyway, plus if purchased from any dealer (Lexus or otherwise)in last 6 months it would also be covered (Sale Of Goods Act)
TigerFish
Can the standard ODBII readers reset the codes? Just an idea but if the error comes up every couple of weeks, can it not just be reset and then carry on as usual? a couple of hundred if that on a reader to reset every couple of weeks rather than a few grand (unless it is covered under the warranty of course).
knitware
[quote name='TigerFish' date='13 May 2010 - 01:19 PM' timestamp='1273753191' post='720069']
[/quote]
The error codes can be reset but they do come back. Doing this just disguises the problem and doesn't give confidence in owning the car knowing there is a problem which needs to be fixed.
Where has the OP gone, have we frightened him off?
The Editor
[quote name='knitware' date='13 May 2010 - 07:26 PM' timestamp='1273775164' post='720113']
[/quote]
He's gone into cardiac arrest!!
As an aside the very fact that Lexus has extended the warranty for this problem to 5 years means they know damn well it's a problem but won't recall and fix it because it's going to cost too much money. However, strange that they have recalled the RX for glass break sensor replacement (which means the alarm goes off occasionally) and I assume this fix is a couple of cheap ultrasonic units which cost pennies. An ECU on the other hand is considerably more !!!!! (Although it shouldn't be as it's nothing more than a few chips (logic gates),an on board cpu and bespoke ROM embedded software .......... I rest my case
The Ed
TigerFish
[/quote]
[/quote]
Yeah, agreed a fix is better. What are the actual concequences of the error though? Is there really a problem, or just spurious error codes that are not causing any damage. My point being that if you don't have 3 grand to chuck at the car, it is an alternative option. or not?
The Editor
[quote name='TigerFish' date='14 May 2010 - 09:18 AM' timestamp='1273825132' post='720155']
[/quote]
[/quote]
[/quote]
It's a software fault in the ECU (which thinks the mixture is too rich I believe) - They have now changed both O2 sensors to a differnet type and updated the software. I think the outcome of ignoring the fault codes is naff all UNLESS the codes put you in 'limp home mode' of course...
The Ed
knitware
[quote name='The Editor' date='14 May 2010 - 03:05 PM' timestamp='1273845945' post='720195']
[/quote]
[/quote]
[/quote]
The Ed
[/quote]
Plus also the car will fail it's MOT if a fault light like Check VSC is flashing. Needs to be fixed but Lexus really should be fixing these faults for free.
Are you there OP?
TigerFish
[quote name='knitware' date='15 May 2010 - 10:45 PM' timestamp='1273959939' post='720363']
[/quote]
[/quote]
[/quote]
The Ed
[/quote]
Are you there OP?
[/quote]
Yeah I agree that they should fix a know issue like this. Even if they don't issue a recall, if it does show itself, they should fix. I assume by the fact that a recall hasn't come about that it doesn't effect ALL vehicles, or does it?
On my origian question on this and restting codes, I'm just saying..... if you do have to pay yourself, and don't have 3k to spend, and there is actually no harm coming to the car, and it only happens intermittantly, then just resetting the codes is a cheap option. If you can reset and be clear for a couple of weeks, you'd have to be pretty unlucky for it to crop up when you have put it in for an MOT. If you can afford the 3k, or Lexus will fix it, then I would fix it properly also.
mojo7676
erm, hello - again
so sorry for not replying to this post in a more timely manner. i didn't go into cardiac arrest or anything but merely had problems with a. my pc, and b. the car!. also, i did check back on the post a few times but nothing much seemed to be happening. anyway, be all that as it may.... an update, i suppose, might be useful.
so, had the computer obd reset thing done twice; the second time i got it done i also noticed a sidelight bulb was out so got that changed. the mech mentioned that sometimes even daft stuff like blown bulbs send these electronics haywire. a friend did some deeper searching online and also found one or two instances of blown bulbs setting off the xmas lights.
so now, about 3 months and not that many miles later (about 1200), the fault has not returned. i'm hoping it was the blown bulb because there's no damned way i'd be forking out 3k; and i imagine the dealers would play hardball if i were to try and pursue it under warranty (now gone over 3 years but the 5 year thing i'm sure they'd still dispute because that is what every dealer i;ve ever dealt with has done).
anyway, got me a new fault. only it's not really a fault - just a heavy and stiff door. i can live with it but it can become a little irksome at times.
hope the update is useful
thanks again for all the replies
mojo
[quote name='TigerFish' date='16 May 2010 - 11:24 PM' timestamp='1274048670' post='720458']
[/quote]
[/quote]
[/quote]
The Ed
[/quote]
Are you there OP?
[/quote]
[/quote]
kosomui
[quote name='mojo7676' timestamp='1278777533' post='725856']
erm, hello - again
mojo
[/quote]
[/quote]
[/quote]
The Ed
[/quote]
Are you there OP?
[/quote]
[/quote]
[/quote]
HI All... Has Lexus confirmed to you that the warrenty is extended to five years for this problem.
keithT
Just like to add that my April 2006 registered GS300 SE had the same issue with the warning lights a week ago, but Lexus Leeds did the full fix at no cost, once I mentioned the LOC Forums thread, and gave me an IS250 Sport for the weekend while they did it.
