[quote name='Kavey' date='Jun 12 2003, 07:56 PM'][quote name='Gavin G' date='Jun 12 2003, 04:14 PM'] Apparantly these wheels come in a 40 offset. Will this be ok for my IS200?
Someone please let me know as I don't want to order them and then discover they don't fit!
Cheers
Gavin
[/quote]
I'm running 18x8 with a 40 offset and it's fine. You can always get spacers to add a few mm offset if they rub.
I kept to 225/40 with front and rear so i can swap the back and front wheels every few thousand miles to help keep the tyre wear even. 235/35 on the back is so marginal an increase in tread I thought the advantage of being able to switch tyres around more beneficial
Asam [/quote]
spacers will actually decrease the offset
40mm offset + 5mm spacer = 35mm offset
40mm will fit without rubbing
unless you go to low
