jonthebarber
June 9, 2003, 9:44 pm
when should they be changed ? eg - which service 40k , 60k etc or is it something you have to ask for ? if so is it hard to do ? eg - could i do it myself ? before you say "look in your sevice book" its in the car and the missus is out in it for a few days . cheers in advance .
Chris.S
June 9, 2003, 9:46 pm
[i]They should be changed on every 60,000 mile service[/i]
jonthebarber
June 9, 2003, 9:47 pm
cheers ears .
jonthebarber
June 9, 2003, 9:48 pm
aaaarrrrrh but are they easy to change ?
Chris.S
June 9, 2003, 9:56 pm
[i]Sorry can't tell you as I've never done them myself, I do know all the air filter box has to come off
I'm sure someone here will be able to tell you[/i]
Parthiban
June 9, 2003, 10:59 pm
the actual replacement of spark plugs is very simple but not sure how complex it is in the lex
why not let the nice people at lexus do it for you?
wildrnes
June 10, 2003, 7:35 am
[quote name='Parthiban' date='Jun 9 2003, 11:59 PM']the actual replacement of spark plugs is very simple but not sure how complex it is in the lex
why not let the nice people at lexus do it for you?[/quote]
erm £75= an hour
Fever
June 10, 2003, 9:41 am
Mr. Matt...you forgot to add Mr. VAT on there!
Small fortune = Lexus man scratching ***** for half your money!
Parthiban
June 10, 2003, 11:42 am
[quote]erm £75= an hour[/quote]
surely it'll only take skilled technicians 5 minutes to do it
wildrnes
June 10, 2003, 11:51 am
i have turned up at a dealership to ave some work done on my car
my car went up at 10 i went up to the viewing area at 10 past to see all the mecs on their t break
on my time
so spark plugs £75+ an hour no problem mate
especially if its arround 10:00, 12:00, or 3:00
BruNo
June 10, 2003, 12:48 pm
if u know how to change sparkplugs with other cars, then u can change ur IS200s. u have to remove the engine cover....all bolts are exposed anyway, then ull see the coils...they hve bolts on them ,,,simply unscrew each one, and use a deep socket for the plugs. thats it. the hardest part will b d last plug nearest d dashboard area, bcoz its a little tight. not really a hard job.
Fidgits
June 10, 2003, 12:53 pm
Surely changing the spark-plugs will be done at your 60K service????
jonthebarber
June 10, 2003, 7:18 pm
as i say i don`t have my service book with me (as i said at the start of the topic) so i did`nt know when they are changed . all i did was ask (cheers bruno) when/how and if they could be done by my local garage/mate . (which looks like they can!!!) . cheers .
bartkat
June 10, 2003, 9:11 pm
Iridium spark plugs should last 100,000 miles. That is unless there is some abnormal conditon that causes them to foul or burn up sooner. You can pull them out and inspect them, and if ok, just put them back in and go.
jonthebarber
June 10, 2003, 9:12 pm
nice one
rhaines
June 10, 2003, 9:22 pm
[quote name='Parthiban' date='Jun 10 2003, 11:42 AM'][quote]erm £75= an hour[/quote]
[/quote]
it takes me 5 mins on the 2 and I'm no trained tech, should take them no time at all, mind you are they one of those PITA companies that charge min 1 hour ? I don't know how lexus dealers work
Full Colour Version:
Spark Plugs !
click here.
