saji
July 16, 2010, 9:53 pm
Would like to know when should I change a timing belt in a GS 300?
Jules7
July 17, 2010, 11:09 am
[quote name='saji' date='16 July 2010 - 10:53 PM' timestamp='1279317196' post='726630']
[/quote]
Just BEFORE it breaks!
Seriously, peoples opinions on this vary, I'm not sure what proper interval is but every 60,000 would be reasonable.
dave1
July 17, 2010, 9:17 pm
[/quote]
Mk 1 GS 300 is every 60k or every 6 years, whichever is soonest. Not sure on Mk 2. A quick phone call to any Lexus dealer would be quickest way to find out if you don't have an owners manual.
WilliamJ
July 20, 2010, 8:05 pm
[quote name='dave1' date='17 July 2010 - 09:17 PM' timestamp='1279401443' post='726713']
[/quote]
[/quote]
I have just changed mine (that crank pulley was pig to undo) and it had done 95,000 miles. It was in perfect condition - could have gone a lot longer. The tensioner pulley was fine . Small amount of play but smooth running)
celssior
August 2, 2010, 1:19 pm
[quote name='WilliamJ' date='20 July 2010 - 12:05 PM' timestamp='1279656350' post='727082']
[/quote]
[/quote]
[/quote]
perfect condition after 95k miles?????????????// get yourself magnifieng glass and have aproper look between the teeth./////////////////////////////////////// 3yrs/40000miles cambelt change interval reccomended by toyota in japan for japanese customers.think about it........
ASWFL
October 30, 2010, 10:21 pm
90k or a little before wouldint hurt.
You might want to also replace the following:
Timing Belt Tensioner
Timing Belt Tensioner Pulley
Water Pump
Front Engine Seals
Serp Belt
Dont wait till its too late then you will be paying big time!!!
strummings300
December 23, 2011, 9:53 pm
[quote name='dave1' timestamp='1279401443' post='726713']
[/quote]
[/quote]
strummings300
December 23, 2011, 10:02 pm
hello i just became the owner of a 300gs wit 126,00 and now needs a service A....this is cambelt and quite a major service as told by the service book and lexus....
for lexus to do the cam and all the followers comes to £500 but is a job that needs attention every 26,000 mls!!but i did ask the tech and he says another 5000 is poss! so its poss that your car wiil be ok and its poss it will break
dave1
December 24, 2011, 9:53 am
[quote name='strummings300' timestamp='1324677778' post='769935']
[/quote]
I don't know where you obtained the above information but it is, to put it bluntly, a load of tosh.
Goochie
January 9, 2012, 9:30 pm
Are any special tools required to hold the cams in place when the belt is removed? When I changed a belt on a 1.6 Vauxhall engine a few years ago it was a simple case of aligning the markers on the 2 cam pulleys.
I presume the methodology of changing it on the GS300 engine is pretty much the same?
Is there a guide online somewhere?
Goochie
January 10, 2012, 3:03 pm
Just been quoted £200 to change the belt and pulleys. Seems reasonable enough to me.
steve2006
January 10, 2012, 3:22 pm
[quote name='Goochie' timestamp='1326207824' post='770841']
[/quote]
If that is including the parts it's a bargain if not with labour rates it's still a good price.
My local mechanic misquoted me on my Lexus V8 cambelt job after Autodata stated 2 hours! 10 hours later the job was done, honoured the quote at £100.00 labour!
dave1
January 10, 2012, 6:16 pm
[quote name='steve2006' timestamp='1326208950' post='770848']
[/quote]
[/quote]
Lexus Coventry quoted around £360 for cambelt on my V8 GS430 which will need doing September. Apparently the GS430 is easier to do than Mk 1 GS300.
click here.
