Full Version: Mk1 300 Towing Question
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
Ryo
got hold of a 1996 mk1 sport, but the harmonic damper on the pulley has gone, and ive not got the proper tool to get the crank bolt off :) my local garage says he will remove it for me , but ive to get the car to him, i cant put the car back together as im awaiting parts for it ,so its a tow job, can you tow a gs300?
the distance between me and the garage is say 15 miles
Cheers
Steve
dave1
[quote name='Ryo' date='18 July 2010 - 10:27 AM' timestamp='1279445255' post='726725']
Cheers
Steve
[/quote]
Not advisable to tow autobox cars unless you disconnect propshaft.
TigerFish
The owners manual says
[quote]
Never tow a vehicle with an automatic transmission
from the front with rear wheels on the ground, as
this may cause serious damage to the transmission[/quote]
but does say in a later paragraph
[quote]If towing service is not available in an emergency, your
vehicle may be temporarily towed by a cable secured to
one of the eyelets under the front or rear of the vehicle.
A driver must be in the vehicle to steer it and operate the
brakes. Towing in this manner may be done only on
hard–surfaced roads for a short distance and at low speeds.
Also, the wheels, axles, drive train, steering and brakes must
all be in good condition.
Before towing, release the parking brake and put the
transmission in “N.” The ignition key must be in “ACC”
(engine off) or “ON” (engine running).[/quote]
I would read "short distance" as being less than 15 miles.
dave1
[quote name='TigerFish' date='19 July 2010 - 11:15 AM' timestamp='1279534529' post='726879']
[quote]
[/quote]
The reason for not towing with rear wheels on ground is because the autobox could be severely damaged because the oilpump in box wont be working. Disconnecting propshaft removes this problem. Ideally towing in reverse with rear wheels on a dolly is ideal.
TigerFish
[quote name='dave1' date='21 July 2010 - 09:33 AM' timestamp='1279701225' post='727124']
[/quote]
Yeah, agreed. In an emergency, a short distance at [b]slow[/b] speed is possible. I wouldn't class 15 miles as a short distance though, more like half a mile, at 5-10 mph max. Disconnecting the prop is definately the way to do it for that kind of distance if towing is the only option.
Full Colour Version: Mk1 300 Towing Question
