Full Version: Gs 300 Mk1 Suspension Bushes
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
clipperman
Hope somebody out there can assist - I'm trying to get hold of replacement suspension bushes (upper rear - both sides) for my GS 300 Mk 1 (1995) so far without any luck.
Does anybody know where I can source these from?
Thanks in advance
TigerFish
The rear upper wishbones are sold as a single unit, I've not seen any aftermarket ones anywhere for the rear uppers. DO you know what has actually gone? The upper wishbone has two rubber bushes at the inner end, and a ball joint at the outer end. It may be possible to get a rubber bush from something else to fit, but no idea if the ball joint can be replaced seperately. Only sources I can think of off the top of my head are Lexus or breakers yards. I would assume if there are after market ones available, your local motor factor shop will be able to tell. Blueprint make front uppers, not sure about rear uppers though.
clipperman
[quote name='TigerFish' date='05 August 2010 - 04:37 PM' timestamp='1281022642' post='728616']
[/quote]
clipperman
Ok - thanks for sharing, I was hoping to get just the bushes (this is what the garage has informed me has "play") - but I guess might have to settle for the full rear unit replacement.
Full Colour Version: Gs 300 Mk1 Suspension Bushes
