One of the MOT failure points was no parking brake effort on the offside. I put new shoes in, adjusted it all up, sent it for retest, and it failed again, still as bad!
I've looked under the car at the cables, and it looks like there's little scope for movement on the offside cable, its got about a centimetre only of pull available, yet the nearside has a good 4/5 cm available to pull the handbrake on. I realise its just one cable that goes round the semicirculat cable guide that is pulled by the foot pedal, but try as I like I cant adjust the cable to have the same amount of pull on both sides! I did manage to move the cable around once, and then put the brakes back together, pushed the pedal down, and still no brakes on the offside, and the cable returned to where it was before!!
Any ideas??
