[quote name='Lexrush' post='137815' date='May 1 2004, 09:40 PM']Hi
I have a 91 celsior with the same suspension problem.could you give me any advice on kickstarting the air suspension or replacing it with a less expensive option?? also looking for english hand book or manual for selsior
[/quote]
Sorry, cant help if you an aftermarket air suspension controller, but if your Celsior has the standard air suspension, and its not working, has sagged low, or the dash 'NORM" light is blinking, first check that the suspension 'on/off' switch is turned on.
Its in the boot inside the tool kit compartment on the left side.
Apart from that, its just the normal 'Tems' (Toyota Electronically Modulated Suspension) sport/normal setting, or the 'Height' high/normal switches on the console next to the shifter.
