General
August 28, 2010, 11:25 am
Hi I tried to change my sat nav disc today, found the box, took the metal cover off and seen a black plastic cover. There's a plastic button that slides across but it just makes a whirring noise and doesn't do anything!
zedman
August 28, 2010, 12:15 pm
[quote name='General' date='28 August 2010 - 12:25 PM' timestamp='1282994717' post='730783']
[/quote]
General,the black plastic slide is also the eject button!!!!
scudney
August 28, 2010, 3:06 pm
[/quote]
hi,press the same button inwards or one near it(if i am not wrong)and this should eject the disc,however make sure the bit that slides across is open and not closed enabling the disc to eject(hope this makes sense?)
zedman
August 28, 2010, 3:19 pm
[quote name='scudney' date='28 August 2010 - 04:06 PM' timestamp='1283008015' post='730797']
[/quote]
[/quote]
As above did mine couple of weeks ago...open slide..push and hold until ejection!!
General
August 28, 2010, 4:00 pm
[quote name='zedman' date='28 August 2010 - 04:19 PM' timestamp='1283008791' post='730798']
[/quote]
[/quote]
[/quote]
Found it! The cd seemed clean, but the 2003/2004 version but it kept coming up with "check data cd". I'm using the original one now but it came up with that error agina, I unplugged it and plugged them back in firmly. Seems ok now but I've got a feeling its just temporary!
scudney
August 28, 2010, 5:44 pm
[quote name='General' date='28 August 2010 - 05:00 PM' timestamp='1283011228' post='730805']
[/quote]
[/quote]
[/quote]
[/quote]
hi,have you got the disc numbers,if you have go to the lexus map update site and put them in,should give you
the latest disc update number(s).Bought the latest for mine(2009-2010) a few months,that is after buying the wrong ones off ebay,so the 2003/04 you have is probably the wrong disc(s).
click here.
