RS200_ADI
September 22, 2010, 8:32 pm
Hi... and greetings to all.....need advise on toyota altezza gearbox....its an auto with triptronic gearchanges on the steering wheel but the manual mode on the steering wheel is not working it just keeps in auto and the buttons do not respond.... not at all.please help?????regards
autogloss valeting
September 23, 2010, 11:12 am
When you move the slector stick from Auto to M - does M engage on your dash, and do you have a gear number on the LCD display at the bottom right of your dash display?(eg D, 2,3,4?)
If not then its the auto ecu not actually switching control to the switches on the wheel.
Remove your centre console and just check everything looks ok under there?
Has this been working before whilst you owned the car?
Cheers
Mike
autogloss valeting
September 23, 2010, 11:15 am
***silly question - have you just bought the car?
Check that you have the dig lcd display on the bottom right of the dash. Also have you moved it from "D" (auto) to "m" on the selector stick?
Reason I'm asking is someone i advised on was very nearl caught out buying and AS200 (6 cylinder 150hp version) which never came with tiptronic - just auto - all the dealer did was put a tiptronic steering wheel on!
Has it got this? ***
