Full Version: Tyres
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
mike_01
Hi all, got standard is200 17" rims on my altezza and I'm in need of a set of 4 tyres as one is comming close to the limit and the other 3 are all different makes, which does't help the handling and feel of the car and they are 225 allround, was wondering if I could put 225/45 on rear and 215/45 on front, or 225/45 all round, has anyone done this or just keep to 215/45 allround also what should the load index be is 91 w ok and what sort of tyres is everyone running as I was thinking either pirelli p6000 or toyo t1-r, many thanks for help
motty
If you want really good grip i would go for yoko prada spec 2's. I would stay away from t1r's simply because they dont have reinforced side walls and with the weight of a altezza it will shred the edges of the tyres quickly. Only problem with running 225 on the back and 215's on the front will be the profile of the tyres will be slightly diffrent, this may make the abs light flash, it has been known on other cars in the past too.
mike_01
ok cheers, yoko's a bit out my price range for now that's why I thought about the t1-r as I've had them before on a bmw and seemed ok, would the p6000 pirelli be better, I would I find out if they have reinforced side walls, many thanks
motty
Yes the p6000 will be better than t1r's if u buy them off the Internet from camskill or black circles they will say in the description if they are reinforced.
mike_01
just checked black circles and it states that the t1-r is reinforced and the p6000 isn't ?
motty
They must have changed the design of them in the last couple of years, because Ive had 3 sets of t1rs and non If them where.
mike_01
could you tell me if this is correct, I went to my local tyre dealer and got some prices for tyres and he said that I need the load index rating which I think was 80 and the speed rating to be what the manufactures state which was a z rating otherwise in would invalidate the insurance, had a look at black circles but doesn't say anything about this, cheers
motty
ive never herd of this, you will probly find hes just trying to get you to spend more on tyres.
Swindon Andy
The load rating is fairly important to get the best out of a tyre. You see specs like XL, or 97Y which are for heavier cars. See tyre manufacturers' sites for availablity listings for each type and size. Tha handbook should specify what you need. Some tyres are available in standard and XL. Some are only available in one or the other. I don't know how the insurance stands on this but I don't think it's dangerous to have the wrong load rating.
mike_01
Ah thought as much, needs to be right though but I think that guy was trying to get me to buy expensive tyres plus having to order speciall rated tyres, think I'll go else where cheers guys
Also reading up I noticed alot of info on the inner tyre wear problem, has this been sorted now or is it still a problem, as I'll need traking doing as my steering wheel is out, would I need to get it done by a proffesional place with the super alignment computer or just your average jo quick fit? cheers all
Swindon Andy
A simple tracking check should centre your steering wheel OK, and may well be all you need. I would rather pay the extra and go for full geometry check and adjust, as you dont really know what's been done to it in an earlier life.
Worth trying to get personal recommendation for a good place, as a poor mechanic can negate the good equipment
Full Colour Version: Tyres
