However, when I got home, it was against the left side of the space, touching the skirt.
I went under the car, and found towards the front of the back box assembly that it is held by a rod through a rubber clip attached to the car.
I readjusted the exit by moving this rod futher into the clip, but after another journey, the pipe had once again moved against the skirt.
My question is, is there anyway I can move the pipe, and secure it so that it remains in the centre, and does not move when being driven.
[b]Update[/b]
Went under the car again last night (and sneezed, which has resulted in a lump on the front and back of my head!
On the original back box, the pins have 'stoppers'
_______|\
-----------|/ Dodgy pic, but you get the idea
The Peco fitments a straight rods, and on either side are just long enough for the rubber clips. To get the exhaust in the correct position, you need the D/S rod to be approx 1cm out of the clip, however, during driving, this will slip back...
The only solution I can think of is sticky-back plastic (too much Blue Peter as a child?) but i will investigate and report back.
