This workshop article relates to the removal of the fibreglass rear bumper section in order to accommodate wiring & fixing of reversing sensors as well as general maintenance etc. It does not relate to the removal of the actual bumper bar, which is the very substantial length of metal running the width of the car at the rear, designed & fitted to withstand accident impact.
The section relating to the sensors, although using an inexpensive alternative to certain other manufacturers, should be virtually the same in installation for most brands.
There are 6 bolts to remove on the outside, and 12 on the inside. You also need to remove a section of rear wheel-arch lining
(2x screws on each) to access one of the outside fixings.
10mm socket & wrench, and a posi-drive screwdiver are the basic tools req’d.
Remove all of the carpets etc. from the boot. These are held together with the push-fit type fixings.
There are 2 screws at the centre section, which are easy to see….
……..and one either side near to the wheel arch.
You then need to remove the small plastic rear section of the wheel arch liner to access the 2 final outside screws (one either side) ………..
Inside the boot, you now remove 4 screws at each side that secure the side sections of the bumper. Be careful not to drop any tools or nuts when doing the side where the CD changer is, as you will spend another 20 minutes unscrewing it all to get them back. (trust me on this one!)
The plastic scratch-strip on the boot ledge pops out (by hand).
and reveals the final 4 screws retaining the bumper…………..
Once the final 4 screws are undone, the bumper is ready to come off. First you need to pull out the screw lug from either side of the outer side section. I found a decent size screwdriver wrapped in a rag so as not to scratch any paint was suitable for this task.
The bumper is now free of any fixings and pulls off towards the rear.
There is only a few inches of play in the wires to the 2 number plate lights, so be careful not to let it drop. As I was only removing the bumper to accommodate my reversing sensors, I did not find it necessary to remove these. I was now able to drill & access the rear of it for threading wires etc.
22mm hole drilled either side for the sensors…………
The sensors I was using required a small degree of modification (due to the non-fancy, inexpensive nature of their manufacture), and had been previously taken apart, painted & lacquered, with the rest of the mounting discarded. A rubber grommet was similarly adapted to act as a new mounting.
The wires for each of them were then passed through each of the 2 number plate light grommets and into the boot.
Inside boot view of number plate lamp grommet/wiring.
Having fed the sensors & grommets through their holes, I then chose to fix and seal behind the bumper with filler.
