robby g
April 15, 2011, 2:07 pm
Hello guys
I've been researching what appears to be a very common complaint on the Lexus is220d about the massive turbo lag and general lack of power. My car was boosting just under 2000rpm but as soon as you went in to second it was flat as anything, almsot to the point of being dangerous.
Last Saturday I decided that I was going to buy a tuning box for it to try and alleviate the lag and some add some much needed low down torque. I have since ordered this. In the meantime I asked my mechanic to remove and check the EGR. He did this on Monday and it was very very carboned up. He cleaned it and the manifold where it had a build up of carbon and sadly it had no effect. He suggested that the EGR could be faulty so I agreed to it being replaced which cost £320 just for the part. This was fitted on Wednesday and very disappointingly, it had no positive effect.
The car now isn't boosting properly (before the EGR was fitted), it starts to boost and then cuts off prematurely and just seems so flat.
I have now put the car in to a recommended technician who is a good 'fault finder' but wondered if any of you guys may have had experience with turbo boost problems? The first mechanic also cleaned the MAF sensor for me.
The car hasn't been seen by Lexus since 2008 so I am unaware if it has had any recalls, ECU updates etc
I'm so stressed out, I just want a car that can be driven. The chip box arrives on Monday but I feel that the underlying problem (the turbo boost) at least needs sorting first before fitting it.
Any advice, suggestion or contributions are most welcomed.
Thank you in advance.
Robby.
ULISSE
April 15, 2011, 5:03 pm
Hello. Connect boost problems to EGR is a big mistake, congratulation to that mechanic. The EGR circuit nothing has in common with air circuit and turbo,it's simply a local feedback circuit to recyrculate exaust gases around combustion chamber (another "intelligent" solution to contain pollutions).
When one turbo car in general has problems with turbo spool up the first thing is to control the Westgate valve, and check if it function and open properly or not.
Consider that big turbolag and dead response under 2000 rpm is typical of a stock is220d first generation (till 2007). To solve this problem i suggest u to mount a "Sprintbooster" (from "Boulekous Dynamic") i did on mine 2007 Lexus and the problem is SOLVED. If u run with this device off after 2 days that u are using it, the car seems simply broken ))
Other problems connected to problem in spool up of turbo could be air circuit intasated, airbox dirty, manifold dirty (very possible if your car has many Km all done with EGR working in stock conditions).
I suggest u to go to a "normal" good mechanic, exaplin him your problem, and ask him to check all turbo air cyrcuit, it will be not expensive, and u'll avoid to change for nothing other parts of the car at jewellery prices has it happen in a official carshop.
Good luck
robby g
April 16, 2011, 8:21 am
Thanks for your reply. I have received an update today stating that they think the cause is the air flow meter (MAF). A new one has been ordered and will be fitted early next week. I shall keep you informed.
Thanks again for taking the time to reply.
ULISSE
April 17, 2011, 1:54 am
mmmm...from the synthoms u described here:"The car now isn't boosting properly (before the EGR was fitted),it starts to boost and then cuts off prematurely and just seems so flat"....they are typical of a westgate that open too early and don't let turbo boost to increase enough; MAF usually give other problems....anyway...let's see.
knitware
April 17, 2011, 7:05 pm
Take it to Lexus, they will fault find. You may think it's expensive but it will be cheaper than getting advice from ill advised mechanics & replacing parts you don't need.
sunterra
April 22, 2011, 6:14 am
[quote name='robby g' timestamp='1302876433' post='752183']
Hello guys
Robby.
[/quote]
is your car before 08/2008
sunterra
April 22, 2011, 7:16 am
[quote name='sunterra' timestamp='1303452864' post='752683']
Hello guys
Robby.
[/quote]
[/quote]
the only reccal ever made by lexus does not include is220d .information about official recalls you Fint in rapex
maybe lexus is trying to hide something
RAPEX is the EU rapid alert system for all dangerous consumer products, with the exception of food, pharmaceutical and medical devices. It allows for the rapid exchange of information between Member States via central contact points (the National Contact Points ) and the Commission of measures taken to prevent or restrict the marketing or use of products posing a serious risk to the health and safety of consumers. Both measures ordered by national authorities and measures taken voluntarily by producers and distributors are covered by RAPEX.
the reccal states the following
Category: Motor vehicles
Product: Passenger car - Lexus GS and LS
Brand: Lexus
Type/number of model: GS450h, LS460, LS600h e LS600hL. Year: 2006 to 2008.
Description: Light Passenger Vehicle. VINs are available in the attached document.
Country of origin: Japan
Injuries
The product poses a risk of injuries because in the valve operating system of the engine, which contains multiple valves in each engine cylinder, there is a possibility that the strength of the valve spring may degrade, causing the spring to break. If one of the springs in the engine breaks, an abnormal noise and rough engine performance will be noticed. In the worst case, the engine could fail and stop suddenly while the vehicle is in motion.
Voluntary corrective actions taken by the importer.
Poland
Bulgaria
Ireland
Hungary
Finland
Netherlands
Sweden
Lithuania
Greece
Malta
robby g
April 22, 2011, 7:18 am
Ye it's an 06 car.
Update: After the MAF sensor was fitted it allegedly drove okay for around 5 minutes, boosting properly. Then it seemed to lose power again. There appears to be a fuel contamination problem. The tank and pump have been removed and contained like a green coloured goo. The fuel line has been cleared but it could be that the pump or injectors are not performing correctly.
To send these items away for testing would cost £50 per item which is normally deducted from any repair costs. However these injectors are non repairable I'm told.
I have therefore had the car transported to Lexus as it wont even drive now and I'll get the experts to diagnose.
The car still shows no fault codes, it's very strange???
I'll keep you updated on how I get on. It could be the high pressure fuel pump? God knows.
I've had a couple of is220d's before over the years and I think this will be my last :-(
sunterra
April 22, 2011, 10:36 am
Dear Robby,
Hi again, as you have correctly stated your car IS220D suffers with lack of power and high build-up carbon within the EGR. Combustion byproduct or none combusted synthetics which accumulate within the manifold and the EGR. The question for all should be why such a high accumulation? In an attempt to explain and understand i will take you through the following process which is highly relevant to common sense as well. As you can see in rapex recall Lexus only consider danger if the spring valve after deterioration becomes broken. What rapex didn't realise in what Lexus has very cleverly stated does not allow consideration over danger for the years before and during deterioration period of before the spring eventually becomes broken. Here must be understood that the only way you can have high build-up of carbon in most common cases is either piston rings or valves and spring valves is the result of high oil consumption. The danger with high oil consumption in this case is not only the build-up of carbon in the parts outside the engine but also within the engine and before the exhaust. This will lead to loss of power, engine cutting out and stalling. This is also a dangerous matter that Lexus did not refer to. With respect to the is220d everybody is puzzling their heads thinking that the problem is within the EGR valve and not with something else that causes the matter of the high build-up. So my advice is check your oil consumption. If you have knowledge of high oil consumption then you should expect high build-up of carbon within everything after the exit valves. The EGR can not be responsible for it, but can only be one of the side effects of high oil consumption, which is more than likely relevant to faulty materials or parts within the engine and the functioning of it (piston rings or spring valve deterioration). Once you realise that anything you do does not resolve the problem then i will suggest you get the head casket removed and check the condition of the engine. Currently the is220d is under my personal investigation and any information we can gather together can be a great benefit.
Happy Easter
robby g
April 28, 2011, 11:04 am
Hi Guys.
After getting a bill for £542 for replacing the EGR and MAF sensors the car got worse. It would tick over but wouldn't rev. I bit the bullet and took it to Lexus last Thursday. With the bank Holidays and stuff I gave them a call on Tuesday. They said that they thought that it was the high pressure fuel. Even they resorted to using the internet they told me.
The pump was £1300 and it was engine out to fit it. I said that After already spending almost a £1000 that they needed to be more certain that just 'thinking' that it's the pump! They agreed to cut the labour rate down to £65 per hour from their claimed £110.00 and also discounted the pump. I also asked them to do an ECU reflashes/updates.
I collected the car this morning after settling the bill for £1939.73 and not only did it run and rev properly, it felt like a different car. The turbo lag from 1st to second was so much better, you caould actually crawl on to a roundabout in second or even 3rd gear. You can put it in 4th at 40mph and it will immediately accelerate.
I've learned a lesson here. I wish I'd gone to Lexus in the first place. Their computer can shut off the injectors one at a time and get fuel pump readings etc The specialist did as much as he could before I took it to Lexus but the next step was to send the injectors off and the pumps for testing at £50 each. That would have been another £300 plus vat down the drain.
Lexus confirmed that my car did have the modded cat fitted and as stated they did the latest ECU update for the vehicle.
I'm poor but I'm happy to have the car back.
Thank you for those that offered advice and I hope that by my leaving the results of my experience that it may assist someone in the future.
Cheers
Robby
ULISSE
May 2, 2011, 9:41 pm
As i supposed the problem of Robby was not connected to MAF or EGR. 1300 Pounds for a high pressure pump? ))))
anyway i'm happy u solved your problem.
writeauthor
June 9, 2011, 9:01 am
[quote name='robby g' timestamp='1303988650' post='753150']
Hi Guys.
Cheers
Robby
[/quote]
Hello Guys,
I am a newbie to this forum, and although my car is not a lexus - i do have the T180 engine in a corolla verso. I am also experiencing similar problems to Robbies original post, having serious turbolag issues that come and go as they please. I just wanted to add to this post after reading all about there being no diagnostic codes recorded in Robbies situation. If the high pressure fuel pump was becoming blocked/restricted, then i would have expected a diagnostic code to be flagged. The common fuel rail has a pressure/temperature sensor installed in it. Surely if the pump performance was decreasing, the pressure in the fuel rail was not being pressurised to the correct pressure (1600-1800 bar) all of the time - THIS WOULD BE REGISTERED AS A FAULT AND AN ERROR CODE STORED!? Maybe even to the extent that the MIL (engine) lamp would be illuminated.
I am still trying to get to the bottom of my problem - going to start with the MAF sensor and air intake and work from there.
Writeauthor
bpv
August 16, 2011, 8:01 pm
Hi all,
I'm new to this forum, I've got a IS 220D 2007, its clocked just over 30000 miles,its been very dependable since i've had it.However since last weekend I've noticed a Turbolag,(apparently a common problem )symptoms exactly as described by Robby g.I took it to a very dependable mechanic, did a diagnostic-which suggested carbon built up, on having a look he could find no excess carbon built up, we went through all the possibilities,(short of changing any parts),including problems with the EGR and MAF .We then proceeded to search online and soon came across this forum and related discussions.At which point we decided, that probably taking it to Lexus (early next week- that's their the first available slot)would be a better option .
I must say I'm not really looking forward to their bill after reading Robby's experience. I just wanted to thank you guys for posting your comments /suggestions which helped me make up my mind.i.e going to Lexus directly instead of taking a longer route.
Will keep you all posted.
Ta
bpv
Full Colour Version:
Is220D Power Problems
click here.
