hakeem1974
July 3, 2003, 11:21 pm
i've got auto airpuri on my gs300 1994 import. anyone know where i fill it up?
DLJ
July 6, 2003, 6:50 am
Whats one of these?????????
norkep
July 6, 2003, 8:22 am
Hi hakeem1974,
In the boot on the right hand side, just behind the tank cover, your will see a black slide cover, pull down the clips either side and pull out the filter, this is the Auto Airpuri, but this filter also doubles for the air con as well. When put a freshner in, use the dried stuff and it will last longer than the spray, if you want to use the spray type, soak the filter in the fuild, the filter will be a cloth material rather than the paper type and will not be damaged but you will need to leave the the Auto Airpuri on auto rather than low or high, by leaving on Auto, the faster the heater/cooler settings, the more fresher gets put in, also if you push the little swtich that regulates the way the air is drawn in - ie - from outside or by recirclateng the air, put to recircalte the auto Airpuri will get rid of the hay fever ploun as well. Kinds off pull the air and filters it.
Leaving on auto will make the freshner last longer. I fill mine up about once every 2 months approx.
DLJ
July 7, 2003, 6:23 am
I guess that this is only relevant to "imports"? mine does not have this filter, which I presume that others are talking about when they qoute the aircon filter which lots of you cant find. I tried all the locations mentioned and definately dont have one!
hakeem1974
July 12, 2003, 12:52 pm
THANKYOU VERY MUCH FOR YOUR HELP ON THIS TOPIC. YOU HAVE BEEN VERY HELPFUL
