uzziz
July 6, 2003, 8:14 am
Hi all
Does anyone know where to purchase the small plates zee and others have on their cars???
your help would be much appreciated..
thanks in advance
Kavey
July 6, 2003, 9:15 am
If you did a search you might find a few threads on this mentioning fancyplates....
Big Pimpin
July 6, 2003, 9:27 am
You'll get them at JAE, Breh!
Solid
[color=purple][font="Impact"][i][b]
BP[/color][/b][/i][/font]
uzziz
July 6, 2003, 9:54 am
tried searching
reg plates
fancy plates etc search executed :
Sorry, but we did not find any matches to display
DUNCAN
July 6, 2003, 9:59 am
[quote name='uzziz' date='Jul 6 2003, 10:54 AM']tried searching
reg plates
[/quote]
[url="http://www.fancyplates.com/index.html"]Fancy Plates[/url]
uzziz
July 6, 2003, 10:05 am
thanks duncan, k8vey,big p
tried searching found some sites but no sure if they sepecialise in designing thoses small plates...
thankss
uzziz
July 6, 2003, 10:12 am
K8VEY your in london
i persume you purcased your small plates in london?????
DUNCAN
July 6, 2003, 10:17 am
[quote name='uzziz' date='Jul 6 2003, 11:05 AM']thanks duncan, k8vey,big p
thankss[/quote]
You can specify the size you want when you order them through "Fancy Plates"
uzziz
July 6, 2003, 10:37 am
so would the size i want be motorcycle size???
Kavey
July 6, 2003, 10:39 am
[quote name='uzziz' date='Jul 6 2003, 10:12 AM']K8VEY your in london
i persume you purcased your small plates in london?????[/quote]
Yeah, but I got a custom sized plate from a mate that worked in Ripspeed in the big H as a special order. Not sure if you can do that sny more as i got my plates years ago before they started doing plate regulations for MOT.
Fancy plates let you specify the size of the pates you want for both front or rear - after you've designed it, you can put in the dimensions you want - Maz (Tony) got a custom sized rear plate for the carbon-fibre trim I got him, like the one linked to the pics in my sig.
KV
Kavey
July 6, 2003, 10:46 am
[quote name='uzziz' date='Jul 6 2003, 10:37 AM']so would the size i want be motorcycle size???[/quote]
Not sure. As I had a jap bumper I just measured the gap then took 1cm off to give me a 5mm border around the gap. This was fine for me with my 5 letter reg and as my car is import I'm allowed to use motorcycle numbers.
The sizes I did my plates were:
Front: 250mm x 120mm
Back: 355mm x 180mm
Not sure if the dimensions are identical for the UK car (Bazza took off the front plate holder iirc and posted some pics), but you are meant to use full size letters on a UK car so make sure they fit before you order the plate.
There was a whole thread on this a few weeks back, and the lettering regulations are on the DVLA site.
Maz
July 6, 2003, 2:18 pm
Hi guys.. well i have my rear on small plate, but keep the front to standard cause of the number plate trim , the rear plate is 360mm x 170mm ( it only look good if you have a plate trim with it, see pic below....upto now i have no problems with coppers, as i used standard lettering and also included dealer name and post code....not sure if it ok when it come to MOT thus....
[img]http://www.lexusownersclub.com/gallery/albums/album01/Maz_Is200_24_6_03_21.sized.jpg[/img]
Loz
July 29, 2003, 9:41 pm
two vendors both from sheffield were at JAE. you should have asked before and we could have ordered you some.. Group Buy anyone??
Full Colour Version:
Small Number Plates
click here.
