XK8BMWLexus
September 17, 2011, 8:43 pm
hi all
new member here and proud new owner of a IS200 2002
i'm looking at fitting a double din dvd player. having had a look at some previous posts/threads i would just like some advice on the connection of the pre-existing amp. it seems as though most people prefer to bypass the amp. is this the best option since i'm not really looking at fitting any further equipment (amps, woofers etc).
and also, is it a relatively simple job to do?
many thanks
DaveEdin
September 17, 2011, 9:25 pm
The IS200 stereo doesn't match the ISO standard used in most aftermarket setups; hence the need to bypass the existing amp.
It's not too difficult to do (even I managed it without resorting to help), and my setup sounds fine without any additional amps/subs etc
The bypassing is simple - attempting to keep the existing amp and connect it to an aftermarket unit - very much wouldn't be.
XK8BMWLexus
September 17, 2011, 10:19 pm
thanks for your reply dave
i've read that you can get the connector which plugs straight to the plug which comes out of the amp. so i'll be looking at getting one of them and hopefully plug into the dvd unit and job done. well, knowing my luck, probably not going to be as simple as that but here's hoping
chargespeed
September 17, 2011, 11:16 pm
Any links to how this is dine please
ormi
September 18, 2011, 12:01 am
no you cant fact......... the only way to get a new head unit fitted is with amp bypass leads..but good luck on finding a lead/making one...
unless your car isnt a sport or se in which case it doesnt have an amp
iceman67
September 18, 2011, 2:41 am
fargo is back on the seen who used to make them so give him a shout for the amp bypass lead
neil
Lexuslee1
September 18, 2011, 6:01 am
Seen a few on eBay just search for them and you'll see
XK8BMWLexus
September 18, 2011, 4:29 pm
thanks for all the replies
will be looking at getting the head unit in the next week or so and fitting it soon after. will post the results for the benefit of other members. if you have any more advice, feel free to post, i will be keeping an eye out.
click here.
