fjcfarrar
October 18, 2011, 12:07 pm
[quote name='XK8BMWLexus' timestamp='1318867030' post='765433']
thanks for the advice. brake control wire connected.
seems as if i've bought a unit with analoge tv
will be needing a digi receiver now i guess.
for anyone else, best place for the aeriel....on the roof!
[/quote]
A simple rod aerial is never going to work all that well but just might be good enough after the digital switchover in April next year when the Digital transmission power will be increased by a substantial amount. A special-purpose type (like caravanners use) aerial is really needed but it[u] must[/u] be omnidirectional. With DTV there is no easy way to aim a directional aerial because you will get no sign whatsoever of a picture, sound or anything at all UNTIL it is pointed in the right direction. DTV is all or nothing. It is not like the analog signal where a noisy picture can be sorted by aiming the aerial for the best results. The only problem with efficient omnidirectional aerials is that they are conspicuous, ugly and look like a metal art-work. So don't settle on an aerial type or position or drill any holes until you have tried a DTV converter, and even then really not until after April 2012. Best to leave this project to one side until then........ or just give up.
