LS400ANTH
October 18, 2011, 9:00 am
Hi Guys,
I need to replace the neutral safety switch this weekend on my LS400. (1995)
Does anyone have a few pointers on doing this....for example anything which needs removing first or tips on how to do it
Anything would be appreciated
Best regards
Anthony
ROYT
October 18, 2011, 11:22 am
[quote name='LS400ANTH' timestamp='1318928416' post='765506']
Hi Guys,
Best regards
Anthony
[/quote]
[b]This is for '94 series two[/b].
Before you replace the switch check this:
loosen the neutral start switch bolt and set the shift lever to to the N position
There is a line on the cover
Align the groove and the line and then tighten the bolt
the groove is on the lower hexagonal below the fixing bolt, tighten 9ft.llb[13 n.m]
This is the basic neutral switch setting
I think you may have to remove part of the exhaust to replace the switch
LS400ANTH
October 18, 2011, 12:05 pm
[quote name='ROYT' timestamp='1318936933' post='765514']
Hi Guys,
Best regards
Anthony
[/quote]
[/quote]
Great thanks for this. I will look into it at the weekend and advise!
Ant
click here.
