Cullers
November 23, 2011, 6:02 pm
Does anyone know what type of bulbs are used in the Mk1 GS300?
I'm looking on doing a complete makeover of the dashboard and centre console.
Although I have seen several project threads, none actually list the number and type of bulbs used.
TigerFish
November 23, 2011, 10:57 pm
The info you need should be in this thread mate
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=64776
The tuturials in my sig below for the AC panel and dash removal should help if you need any info on taking them out/apart.
Cullers
November 23, 2011, 11:02 pm
@Rick - thanks for that mate. That is spot on what I want. I followed about four different tutorials and they all pointed to buying the lot from a single source who wasn't replying to email.
Thanks a ton bud!
wow300
November 25, 2011, 10:04 pm
I used these people, great service
http://www.ultimatemods.co.uk/led-car-bulbs.html
You need T5 509T LED bulds and some 286 led T5 wedge for the heater panel i think, cant quite remember which they were for now
Cullers
November 26, 2011, 12:30 pm
Right, I've taken the plunge and ordered ten of each. Not sure if that is enough. Made sure to get the flat headed ones as I've read that they are more even in terms of light distribution rather than the domed headed ones.
Also ordered some HID and high power sidelight bulbs. Shame I can't find something suitable for the rear clusters
Unless, of course, someone knows differnt?
Cheers Wow300! Appreciated your input.
TigerFish
November 26, 2011, 12:40 pm
What do you mean for the rears? I've not seen any aftermarket clusters, but from what I remember you can de-tango them.
Cullers
November 26, 2011, 3:59 pm
Was hoping that there might be some JDM clear rears. Funnily enough, they are plentiful for the Soarer market and the IS but neither sight nor sound of them for the 300/Aristo. Can't even find clear side repeaters either. The ones on currently are smoked by a previous owner but to say they look bad is an understatement of mammoth proportions. I aim to detango the fronts and am thinking about doing a separation in order to insert angel eyes or DRL's
TigerFish
November 26, 2011, 4:04 pm
the clear side repeaters off the RX300 (I think it was) fit the mk1, which is what I did when I had mine. Having said that, there are clear (not crystal) ones on ebay at the moment for £15 a pair plus postage. The genuine items like I used will cost more than that.
Must admit, I've seen nothing for the arse end of jzs147, other than a de-tango or DIY smoke, I don't think there is much choice.
Cullers
November 26, 2011, 8:08 pm
Rick, do you have link to the clear ones on ebay you mention? I can't find them.
Cheers matey
TigerFish
November 26, 2011, 8:31 pm
This is for the clears,
[url="http://www.ebay.co.uk/itm/Clear-Side-Repeaters-LEXUS-GS300-PAIR-/140637824661?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20beaae695"]clear side repeaters[/url]
and there are some crystal ones too here
[url="http://www.ebay.co.uk/itm/Crystal-Clear-Side-Repeaters-LEXUS-GS300-PAIR-/130599651113?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e68588729"]crystal side repeaters[/url]
Cullers
November 26, 2011, 11:40 pm
Cheers Rick. Purchased. Definitely going to have to detango front and rear.
Keith Bowler
November 27, 2011, 2:37 pm
After a couple of years deliberating whether to sell my car or not I have decided to hold on to it for a while longer and get some of those niggly jobs done.
In the interior around the dash and centre console I have a lot of dead bulbs that I'd like to replece.
I have sorted the a/c control and hopefully the head unit, just need to fit so will be following TigerFish's tutorial on removal and replacement of these.
Need to do the gear change selector panel by the gear lever but not sure where to look for the bulbs and also need to know if there is any interior lighting around the coin tray and rear fog lamp switch.
Any help appreciated.
TigerFish
November 27, 2011, 11:02 pm
there are two bulbs in the gear selector, similar bayonet types as the AC unit but I can't remember off the top of my head which size, probably the larger ones. Once you have the panel out, it is obvious where they are. The pic below was from my mk1, so the fog and headlamp height adjuster should be lit.
[img]http://www.lexusownersclub.co.uk/forum/uploads/monthly_10_2007/post-19263-1192307400.jpg[/img]
Keith Bowler
November 28, 2011, 10:14 pm
Cheers - I did think it was a little odd that there was no backlight to the headlamp adjuster/rear fog switch, just need to find out where the bulb is and how to get to it.
TigerFish
November 29, 2011, 12:03 am
[quote name='Keith Bowler' timestamp='1322518494' post='768256']
[/quote]
Not sure if the mirror adjustment switch should be lit or not, it wasn't in my pic, but it could've been blown.
click here.
