Power/Battery Drill
22mm Circular drill bit with Mandrake bit
Silicon sealant
cable ties
The Quanan Kit
First of I positioned the sensors using masking take in verticlas stips. I then measured the distance apart. The measurements are listed whithin the installation guide
The when the measurements have been made so be equal distance apart horrizontially and vertically from the top of the bumper.
To make sure I did not hit any bumper irons in side the dumper I decided to drill pilot holes. This was mainly for testing and also easier to drill with the 22MM bit later on.
Then usaing the circular bit I drilled out the holes
