[quote name='LEXMAN' date='Jul 13 2003, 01:07 PM']My rear brake light went out today and i need to replace it.
Had a quick look, it seems i have to remove the whole light to change bulb...is this right or was i imagining it.[/quote]
Hi Lexman,
Depends on which bulb has blown, the ones in the side or on the boot lid, if the boot lid, then the covers that go over the units will need to be removed, only a five minute job, how-ever -
if the side, then the whole back plastic cover will need to be removed but these are cliped in only are easly removed, only looks a lot, but there are 3 clips holding in the cover, once you have these off, getting to the bulb is easy, twist out and replace.
Paul
