lil_rob
January 3, 2012, 7:23 pm
Hi guys looking for a induction kit for my 200 but they all seem stupidly price anyone have a used one for sale or a diy guide on how to.make one?
Any recommendations on filter? Heard apexi the one to go for.....
Thanks guys
btw already posted in the wanted section lol
Lance
January 3, 2012, 7:34 pm
There is no induction kit available for the IS200 that will give significant gains above the standard airbox and hi-flow panel filter. In fact some will actually cause the car to lose power.
JezaLexy99
January 3, 2012, 9:18 pm
If you look on the IS200 forum, theres a topic from Sprinter, he made his own system with a Apexi filter. He makes and sells them, but hes also got all the parts listed down u need, roughly around £150 i think all in all. Pretty easy to do if youve got a weekend free. And it looks the dogs nadgers!
if you need any ifno ask him..im sure hel help, but its a really handy post.
lil_rob
January 4, 2012, 9:43 am
Well i have had a look on ebay.... for 1m alloy pipe and all the silicon bits (without the reducer for the filter- obviously size of reducer will differ from filter to filter) works out just under £40 (excluding filter) will post item numbers up if anyone else needs them.....
JezaLexy99
January 6, 2012, 11:54 pm
yeh thats it...so if you find out what side the filter is then your sorted. Apexi are 90quidish..so yeh..£140-150 ish all in all..not bad cein as there are systems around for 2-300ish
esp
January 19, 2012, 9:34 pm
I am running a Pipercross replacement element in mine very slight diffrence in noise.
Twins1984
February 1, 2012, 4:00 pm
what do you think about this one? [url="http://www.dcperformance.co.uk/uprated/pipercross-pk-induction-kits/lexus/is200.html"]http://www.dcperformance.co.uk/uprated/pipercross-pk-induction-kits/lexus/is200.html[/url] or would self-made apexi kit work better?
andyk134
February 4, 2012, 2:44 pm
Advice I had from 2 specialists as that a good uprated filter gives the same as an induction kit so dont waste your money. The standard system works well, unless you are just doing it for looks.
fjcfarrar
February 4, 2012, 5:12 pm
[quote name='andyk134' timestamp='1328366688' post='772664']
[/quote]
The specialists are half correct. No induction kit will make any measurable difference to IS200 performance. But panel filters etc. won't either unless as a replacement for a severely clogged OEM Filters. "Uprated" filters could allow extra air to flow; but the engine is incapable of asking for any extra air unless a supercharger or the like is fitted. The original filter does not impose a detectable restriction in flow on the standard engine.
The only reasonable excuse to fit these is to get stuff that looks pretty, is useless but doesn't do any harm. Both can change engine noise - which you could use to convince yourself amounts to improved performance & flexibilty.
PatrickM
February 6, 2012, 6:40 pm
I just had my Lexus on the Dyno last week, and it lost 4HP with the Pipercross Induktion kit, compared to the stock intake with KN filter panel.
It put out 154HP with Stock intake and KN panel filter and 150HP with Pipercross induktion, and the graph was looking mutch smoother with the Stock intake aswell.
Twins1984
February 24, 2012, 5:24 pm
[quote name='PatrickM' timestamp='1328553649' post='772875']
[/quote]
thanks for info Patrick. It's good to have a proof from dyno of what is actually happening after modifying your car. Does your car have a modified exhaust?
PatrickM
February 25, 2012, 5:37 pm
The only things that was done on the car before the dyno run was the KN Filter panel and a HKS Silent Hi Power exhaust.
The car put out 154HK and 219NM at the wheel. So really pleased with the result
Full Colour Version:
Is200 Induction Kit?
click here.
