Full Version: Gs300 Fuel Line Location…Help!
Lexus Owners Club > General Lexus Forums > Lexus General Maintenance
Oneightycd
Hi All,
Can someone please show me where the fuel line enter the engine on a 56 plate GS300 SE Limited Edition?!
I'm not a mechanic (obviously) and when I lifted the plastic engine cover was blown away by the amount of pipes going into the engine!!
Someone help please!
dave1
[quote name='Oneightycd' timestamp='1325955938' post='770640']
Hi All,
[/quote]
All 56 plate GS 300's will have the fuel pipes in the same place. Is there a particular reason that you need to see the fuel pipe?
Oneightycd
Hi, I'm thinking about some improvements and I'm just planning.
Can you direct me where and what I'm looking for?!
Ta!
A
dave1
Not trying to offend or be "clever" but following what you have posted, and that you say that you have no skills as a mechanic and are unable to recognise your fuel supply pipes, I would be concerned that you feel you can improve the fuel system which is standard on your Lexus. What improvements did you have in mind?
Oneightycd
Hi Dave,
No problem!! :-) Basically I have a fuel saver (power mag) which I'm going to try and it simply cable ties to the fuel line as near as possible to the engine!!
Thanks again!
A
dave1
There are also devices enabling you to run your car on water!
http://www.popularmechanics.com/cars/alternative-fuel/gas-mileage/4271579
Oneightycd
Thanks Dave but maybe a step too far!!
Any help with fuel line location would be truly appreciated!
A
