tof
Aug 17 2003, 12:00 PM
Hello,
can i use K&N cleaner and oil on a TRD air filter?
It easier to find K&N here in Belgium than TRD parts.
How many kilometers before wash it?
Monster-Mat
Aug 17 2003, 12:46 PM
if yours is the is200 6 cylinder motor with the drop in TRD filter, then you CAN NOT wash the filter it is a throw away part
tof
Aug 18 2003, 05:37 PM
I think that the TRD air filter can be washed.
I many kilometers before change it?
Is there an air filter for the 1G-FE that can be washed many times?
Rob
Aug 18 2003, 07:31 PM
i dont know after how long you should change the filter - it all depends on its condition- but i do know that if it is the red TRD filter that is a straight replacement for the original white one the you CAN NOT wash it, it is not like the K&N filters - it is not intended to be washed, but you can give it a try.
At the moment there is no filter that is designed to be a straight replacement that can be washed.
bam-bam
Aug 18 2003, 10:21 PM
My car runs the 1g-fe engine,and we just sourced a Trust washable air element for around 140 NZ $ (with freight),they are indeed available via Hong Kong....
Rob
Aug 19 2003, 04:58 PM
is this a fairly new item then??? because when ever i have looked at trust products the only thing i have seen are the mushroom type filters
Gus
Aug 19 2003, 09:04 PM
hmm ... have been looking for a "drop in" sport filter also but didnīt think it was available.
Monster-Mat
Aug 19 2003, 09:11 PM
i personally wouldnt wast my time on the trd drop in filter.
just my opinion.......the reason is, both filters i.e the factory and the trd filter look identicle, apart from the fact, the trd one is red.
Gus
Aug 19 2003, 09:17 PM
QUOTE(Supracharged-IS340 @ Aug 19 2003, 10:11 PM)
hmmm matches my socks then ...
ok , so no extra power o better sound with it, have to go with the "mushroom" filter for that and have to rebuild a hole lot of stuff :[
bam-bam
Aug 19 2003, 10:33 PM
Sorry monster,I have to differ slightly-the one I got differs HEAPS from the factory one... and it's yellow!
0-100 time has dropped slightly also-same road,same time of day,same conditions.
Take a look see at a
Pic of trust filter for 1G-FELemme know your thoughts?I'm unsure what comes factory in th UK,but on my Altezza its a crummy,non-breathing,paper item.
Regards,
Gav
Monster-Mat
Aug 19 2003, 10:40 PM
im not refering to your yellow filter.......
im refering to the TRD red paper filter....thats why i said TRD DROP IN FILTER
bam-bam
Aug 20 2003, 02:51 AM
doh! my bad.... obviously not reading things proper.
GXE10
Aug 20 2003, 03:18 AM
but the TRD filter is much more thinner than the orginal filter
Monster-Mat
Aug 20 2003, 08:03 AM
.............that alone doesnt make it better
kev dood
Aug 20 2003, 08:15 AM
Didn't think that foam filters were that great. Longevity wise mainly, hence people like cotten ones better.
Think the issue was to do with if stones get in it can break up the foam and when they get older it comes off etc and into the air intake! Not that great! It also leaves holes or gaps in the filter.
So Mat, the TRD one is not worth it then - what other options (if any) are available as a drop in panel filter?
ColinBarber
Aug 20 2003, 10:12 AM
TRD stuff is normally very good. They state the filter is less restrictive and last longer than the stock filters. Maybe the gain is so small it's not worth the money.
http://www.toyota-trd.com/en/strt/e_airfilter.htmlYou have to be careful will some filters as they although they may give performance gains they don't filter well and you could end up damaging your engine.
http://www.mkiv.com/techarticles/filters_t...st/1/index.htmlhttp://www.mkiv.com/techarticles/filters_t...st/2/index.html
lextcy
Aug 21 2003, 04:19 AM
You could probably just use a high pressure air blast to clean it
Monster-Mat
Aug 21 2003, 09:43 AM
i think were going off topic here.....the original post is about cleaning the paper element trd drop in filters............
which are throw away filters........
tof
Aug 21 2003, 06:44 PM
Thank everone for your help.
I think i'm going to buy the Trust air filter like Bam Bam.
I saw Trust Airinx II airfilter on Taka kaira website for the 1G-FE.
Is it the same like you Bam Bam?
It's only 33 US$ + freight.
click here.
