Do the new models have a revised gearbox?
The reason I ask is that I have had an IS200 Sport for nearly three years now and in that time I have never been happy with it (the gearbox).
Initially it was silky smooth but it soon developed the dreaded clunk into second gear problem. I got the "they are all like that" routine from Bristo's Ipswich. Then it started lurching with little touches of the throttle when trickling in traffic. And the final straw was when it started "going to sleep" when trying to pull out in to traffic.
The guy from Lexus cam to Bristo's and said that the syncromesh parts needed replacing and that they would fit new air sensenors (flow measurer?). This was done and all was OK for three months, then it was back to the problems above.
Bristo's lost / gave away (depends who you talk to) the franchise and now Hadleigh have it. Chris their head tech has been most helpful and after many calls to Lexus the GEARBOX was replaced, at the same time as a new set of alloys were fitted. He also reset the ECU and all was fine for a short while.
The lurching and non-responsiveness has returned again along with the most awful rattle when pressing or releasing the clutch (although gear changes are smooth). This is most noticable in reverse. I have driven their demonstrator and if anything it was the same or worse than mine.
Chris is now arranging for the Lexus rep to talk direct to me as he has been told he can't replace the box again (we'll see about that).
I feel sorry for the dealer as they are stuck between the customer and Lexus UK, but at the end of the day the gearbox and engine management system is
What would you do?
Mike Roberts
Ipswich
